Old 08-21-2008, 06:54 PM   #16
wes95_z28's Avatar
Originally Posted by DOMIT View Post
"you gotta be kidding me" sloppy
Is that a step above or below "holy s*&t" sloppy? lol
Wes
Kyosho 777 WC w/ big bores, RB S5, ACE 1313 s., Air 357 t., JP-3
HPI Savage X SS, Axial .28, Hitec 5645 Steering servo
Nitro TC3, O.S. .18 CV-R
Associated RC18T, Brushless, Lipo
wes95_z28 is offline   Reply With Quote
Old 08-22-2008, 07:00 AM   #17
Ok, so that seems to be the problem. I have to remesh the gears just a hair looser. Is that why they seem to go thru clutch bells quicler than other buggies? Think I may change to the hardened ones that I have to help with the wear.
843rcguy is offline   Reply With Quote
Old 08-22-2008, 07:47 AM   #18
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Yup... even with the King Headz mount there is a LOT of flex there on the Losi, and it just beats the clutch bell up... you're lucky... I was killing bearings AND clutch bells when I had my Losi.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 08-22-2008, 10:09 AM   #19
Toiffel's Avatar
Trader Rating: 52 (100%+)
843RCguy
I'm having the same issues on both my truggy and buggy, tried every other bearing out there, more play less play on the clutch bell, new bells old bells, stock motor mounts-king headz motor mounts, different engines, tighter mesh-lose mesh, and still the same problem.
So I called up Losi and spoke with a really cool guy called Bill G. and he gave me the following pointers:
Obsviously go thru the check list above, and add the folliwing:
clean out the bearings, removing any excess oil (with air gun) you don't want the oil to migrate into the the clutch bell,causing it to overheat, remember bearings go bad for two main reasons 1st heat 2nd excessive vibration
clean the clutch bell, shoes and pilot shaft area with alcohol (leaves no oily residue and evaporates quickly)
remove any glaze on the composite shoes, and specially if you run all aluminum shoes, take a dremel all sand the inside of the clutch bell eliminating any residue and clean with alcohol. you don't want excessive slip, again it's a heating issue.
when intsalling motor mounts, first with the engine then proceed to screw them on, 2nd mount it on the chassis pushing engine all the way to the front (this is to make sure that engine is completely straight -avoiding vibration-),
this part is crucial, *****you should set the mesh up with the least amount of play possible, try using the plastic bag from the losi parts instead of the paper thing, this will give you the least anount of play, but just enough that under flex you won't ruin bearings or anything else.*********
Don't forget to make sure that the clutch nut is properly tightened and not come lose........
Hope this helps......
Toiffel is offline   Reply With Quote
What can cause excessive clutch bell bearing failures? MattP Nitro Off-Road 13 04-29-2008 07:06 PM
Clutch bell bearing problems rltanner Nitro Off-Road 14 02-20-2008 12:52 PM
Removing a stuck thrust bearing from the clutch bell Darthswan Nitro On-Road 0 08-01-2005 10:13 AM
WANTED:Savage parts-clutch bell, clutch shoes, rear driveshaft,etc..Orlando, Fl. 10gter Florida Racing 0 01-26-2004 08:54 AM
kfactory ntc3 30mm push clutch bell to mugen centax clutch set mugen_kid Nitro On-Road 1 03-04-2003 04:01 PM
