Old 08-06-2008, 09:59 AM   #1
Akhor's Avatar
Default Chasing a Tune
I've got a new engine that I just cann't seem to get a tune on. Sometimes it will idle forever, other times not at all. I've tried re-setting to factory and going from there, but it was soo rich it just conked out.
However, before I left the track last night I found that the rubber hose leading from the air filter to the carb had a crack in it. Is it possible that this is the issue?
Akhor is offline   Reply With Quote
Old 08-06-2008, 10:15 AM   #2
get a new air filter and then go from factory settings but just lean it out some from factory so its not so rich and then go from there
www.nitrojunction.com
The #1 site for all your nitro needs
egobuster1 is offline   Reply With Quote
Old 08-06-2008, 10:23 AM   #3
Akhor's Avatar
Ya I kinda figure that the hole in the air filter might be causing a huge issue.
I hope to find out this evening.
Old 08-06-2008, 10:47 AM   #4
scoopdaloop's Avatar
Trader Rating: 10 (92%+)
Send a message via AIM to scoopdaloop
Yes that could be your problem, go ahead and get a new air filter. Make sure that your idle screw is set properly so that the same idle will be had each time.
scoopdaloop is offline   Reply With Quote
Old 08-06-2008, 12:24 PM   #5
desertbird's Avatar
An air leak ANYWHERE in the engine system will cause erratic performance. This includes the engine's back plate, pinch bolt, carb seat, HSN needle housing, carb Slide/boot, Bearings, fuel lines, and gas tank. Some of these can be sealed i.e. back plate, pinch bolt, HSN housing... some need to be replaced i.e. gas tank, fuel lines, bearings, and carb slide boot.
Go through your entire system to ensure its tight if your engine has performance issue, even brand new engines can have air leaks.
desertbird is offline   Reply With Quote
Old 08-06-2008, 12:37 PM   #6
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
i had a brand new sirio evo 3 that leaked like crazy!!! a little sealent and she was good to go for about two gallons!!
jamminnay is offline   Reply With Quote
Old 08-06-2008, 01:12 PM   #7
Akhor's Avatar
Good to know. I'll defiantly check it all out and report back!
Old 08-07-2008, 07:12 AM   #8
Akhor's Avatar
Actually, I went through the fuel system last evening and found a hole in the gas tank when I pressure tested it.
So, I'm guessing this was the cause of my issue.
From JP-1 to JP-3= out of tune question. malik Nitro Off-Road 12 06-05-2008 06:11 PM
how to tune RB engine? golem Malaysian R/C Racers 12 03-01-2005 11:32 PM
REX PR321P Tune Ah10 Onroad Nitro Engine Zone 11 02-23-2005 08:27 AM
Police go to find Elvis, wind up chasing one of the Blues Brothers MarkA Chat Lounge 0 10-13-2004 10:14 AM
Chasing Speed ratter Electric On-Road 46 06-01-2004 09:19 AM
