Old 08-05-2008, 12:40 PM   #1
Default Jammin X1 CR front dog bone
I have a X1 CR that I raced last year with big bore shocks without any issuse's but these season I put super big bores and now I am have the front dogbones comeing out of the outdrive's any idea's nothing seems to broke the droop and ride hight is set the same as always.It came out 4 times in a 30 min A main.
AK-driver is offline   Reply With Quote
Old 08-06-2008, 05:49 PM   #2
NZDriver's Avatar
You sure you have the fronts installed in the front and not in the rear?
the rear UJ's are slightly shorter than the fronts. Ive also had this problem before, it was a case of not being aware of the difference when i reassembled the buggy
Losi 8ight 2.0/OS Speed
Xray T2'008/Tekin RS
Kyosho SC-R/LRP
NZDriver is offline   Reply With Quote
Old 08-06-2008, 08:56 PM   #3
SKOT's Avatar
It could also be a worn diff outdrive.
Taking out some droop may work as a temp fix.
http://www.rcsignup.com/racers/displayRacer.cfm?ID=215
SKOT is offline   Reply With Quote
Old 08-07-2008, 09:25 AM   #4
-R2-'s Avatar
yeah I would say the unversal is the wrong one, to tell if you have the right one in there it will have 2 round ribs in the middle of the shaft.
-R2- is offline   Reply With Quote
Old 08-07-2008, 11:04 AM   #5
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Yup... and when they wear out... replace them with the Kyosho ones. They last longer. As someone said though, if your diff outdrives are really worn it could cause this. I have one with a slight chip on the "corner" of the slot, and I've had that happen ONCE.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 08-07-2008, 11:49 AM   #6
Default thanks
After close inspection all I can find is a chipped corner on the out drive I am going to put a new out drive and shaft some new bearings and try it again its probly time to put some fresh diff oil in anyways. Mark
Old 08-07-2008, 01:33 PM   #7
DOMIT's Avatar
The chipped outdrive will certainly cause that. Replace it and see if that resolves it.
Old 08-07-2008, 11:18 PM   #8
check for slop or cracks on the arms, c-hubs and knuckle arms. Anything loose at the hingpins or kingpins could also be causing the problem. Your upperarm holding the turnbuckle could could be stripped.
Genius is offline   Reply With Quote
Jammin X1 PBS Front Suspension Conversion...fs cheap NitroLuver R/C Items: For Sale/Trade 6 08-25-2008 09:20 AM
OFN40570 Jammin CRT HC Front Knuckles ffpm46 R/C Items: Wanted to Buy 0 06-26-2007 01:47 PM
Jammin Big Bore Front and Rear Shocks J_Longbrake R/C Items: Wanted to Buy 0 02-25-2007 08:47 AM
wanted front dog bone for savage 25 rt-maxx R/C Items: Wanted to Buy 0 12-11-2006 12:18 PM
X1 CR Jammin shock set front and rear dazyz Australia For Sale/Trade 0 02-27-2006 10:32 PM
