Old 08-01-2008, 08:33 PM   #1
Default X1 crt
OK so i have an x1 crt and was wondering wat upgrades are a must need i dont have the crt pro just the rtr.As of right now the upgrades i have are a Werks B7 .28 team line,(10 tanks through it) JP-3 pipe, jrZ650 servo for steering, better tires,Spektrum radio and thats it that i can think of
any help would be greatly appreciated
Losi 8 Tekno conv. Neu 1512 2d/f Phoenix 85 Max Amps 4s 6000 DX3
X1 CRT,Werks .28 B7 teamline,JP-3,DX2
jlinds is offline   Reply With Quote
Old 08-02-2008, 01:39 AM   #2
from the top of my mind I can suggest a z-brace to avoid excessive chassis flex and big bore shocks.
Genius is offline   Reply With Quote
Old 08-02-2008, 02:42 AM   #3
Jerseyboy's Avatar
you need z-brace, front and rear cnc brace this is critical.
then rear wing stay posts in cnc. Hinge pin set also very important. That should be all.
Jammin X1 FTE
Upgraded to Warp Drive
KO Mars Ex-1 Spectrum Telemetry
Jammin JPX 21/OS Speed
Jammin X1 CRT
Go tech 21 5p
Upraded to Stelar Galactic
Jammin X1 CRT.5
Power by SH12
Either your Jammin or losing"Catch me if you can"
Team Dramatic
Jerseyboy is offline   Reply With Quote
Old 08-02-2008, 07:52 AM   #4
Integra's Avatar
screw the Z brace and get a KH motor mount...it basically does the same thing as the Z brace but makes the motor Easily removable with 4 screw's.......U NEEED chassy braces if its the RTR...those stock units tend to fail pretty easily.....and if can find a CF or Alum steering top plate that would also be a good investment......basically u want most of the Pro parts....but since your starting with nothing...u can go with the Good parts like KH toe plates and maby some KH tower's down the road....here's a link to a bunch of parts and hop ups.
parts in general
http://www.amainhobbies.com/index.php/cPath/1_24_151
KH stuff i HIGHLY reccomend.
http://www.amainhobbies.com/index.ph...&filter_mfr=25
Old 08-02-2008, 08:42 PM   #5
Trader Rating: 39 (100%+)
I would suggest a pro chassis as well as the alum braces and z brace. I put the z brace and alum chassis braces on my rtr still had enough flex to bend the front center drive shaft. Runnin pro chassis now with braces and z brace no problems .
Dragtruck is offline   Reply With Quote
Old 09-01-2008, 10:59 PM   #6
wcrase101's Avatar
Send a message via Yahoo to wcrase101
Default take out those plastic bushings
in the steering and brake areas there are plastic bushings they break fast or wear down fast, put some bearings in there
wcrase101 is offline   Reply With Quote
