Old 08-01-2008, 07:37 PM   #1
2005 crf 450's Avatar
Default What piece is this called?
Its the thing that you put on the end of the metal rod on the carb that goes through the servo arm, so when you accelerate, it actually opens the carb instead of just slipping the metal rod through the plastic piece. It has a 1.5mm set screw in it to tighten to it doesnt fall off the small metal rod.
Sorry thats a horrible description
edit: also, how can I get a hold of tony from tonys screws. thanks.
2005 crf 450 is offline   Reply With Quote
Old 08-01-2008, 07:42 PM   #2
mike williams's Avatar
Trader Rating: 45 (100%+)
slide end pivot ball?
http://www.amainhobbies.com/product_...ducts_id/12417
LOSI MF2 ....... too fast for me!!!!!!!!
mike williams is offline   Reply With Quote
Old 08-01-2008, 07:43 PM   #3
crazy4wdracer's Avatar
Trader Rating: 25 (100%+)
Send a message via AIM to crazy4wdracer
Tony from Tony's Screws has a name on here.
crazy4wdracer is offline   Reply With Quote
Old 08-01-2008, 07:50 PM   #4
imaxx21's Avatar
Send a message via AIM to imaxx21
http://www.amainhobbies.com/product_...oducts_id/3291
tony@tony1034.com
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 08-01-2008, 07:52 PM   #5
Originally Posted by mike williams View Post
nope. theres a piece of metal thats on the carb, and it goes through a plastic piece on the servo arm, it slides onto the metal rod, then you put a 1.5mm set screw in it. Basically without this tiny piece you cant drive your car, because you couldnt accelerate.
Yes, I know he does, what is it?
Old 08-01-2008, 07:52 PM   #6
thank you very much imaxx.
2/2
Old 08-01-2008, 07:55 PM   #7
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Sounds like your talking about the throttle linkage rod and the other piece is the linkage end stop or stopper. Or is it the actually plastic swivel that holds the rod to the throttle servo horn?
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 08-01-2008, 07:56 PM   #8
imaxx21's Avatar
-Crash
Old 08-01-2008, 08:15 PM   #9
the technical name for it is a collar, with a 3x3mm (1.5mm head) set screw in it. they range from 1.50 - 4$ each
Old 08-01-2008, 08:44 PM   #10
imaxx21's Avatar
i just linked you a pack of 2 for $2.19
-Crash
Old 08-01-2008, 09:03 PM   #11
yeah I know, thats where I got the 1.50$ from. I bought 2 packages of those and it was 5.95. There were others there for up to like 4.50 each.
Old 08-02-2008, 03:01 AM   #12
razzor's Avatar
alluminium stopper
http://www.rceasy.com/wp-content/upl...7/61408_01.jpg
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
what is the carpet you race on called? azenis Electric On-Road 5 08-11-2004 11:54 PM
CustomWorks oval pan car is called...... jeepnyy Electric On-Road 6 04-22-2004 04:48 PM
Oops should have called a tow truck corwin Canadian R/C Scene 6 01-29-2004 11:53 PM
The Teaher should be called The Preacher BigDogRacing Buyer/Seller dispute and Feedback discussion forum 0 09-18-2002 10:54 AM
