Old 08-01-2008, 12:06 PM   #1
Default RB WS7III
My registration for the RB Concept forums was declined for some reason so I'm hoping someone can provide some insight for me. Perhaps someone who has had a WS7III or experience with RB engines.
I'm trying to perform the RB style break in on my WS7. Which calls for idling 125CC through it on the box. I can get it started and running just fine, but it's the temperatures. It temped as high as 244 just idling. I thought maybe my temp gun was giving me false readings, so I dropped some water near the glowplug and it immediately sizzled and evaporated. I had started with a foil wrapping over the head, but immediately realized that wouldn't be necessary.
It's blowing a fair bit of smoke, and leaving a good coating of oil on my patio slab. If I try to richen it any further on the low end, it will stall. I can richen it a bit further if I leave the glow igniter on the whole time it's running, but the engine still runs 220-240.
I added a shim so I could run Sidewinder 30%. I'm using a JP-3.
Any thoughts?
Semple is offline   Reply With Quote
Old 08-01-2008, 12:40 PM   #2
wingracer's Avatar
Trader Rating: 23 (100%+)
That is a good thing. Never break them in cold.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 08-01-2008, 01:08 PM   #3
I should not be alarmed that the engine desperately wants to hit 250 degrees? I mean, there is smoke and fuel coming out of the pipe, and I know Rody himself is an advocate of tuning without a temp gun.
So, basically, I'm not going to pooch the motor if it idles at 240?
Old 08-01-2008, 01:12 PM   #4
Nothing to worry about at the moment. It will cool off as it breaks in. 240 is a little hot for me, but you won't damage anything. You can leave the ignitor on the plug, richen the mixture and you can get it to idle cooler.
I do the full throttle, full rich, break in method for three tanks, then I start driving the car starting at 150 and working my way up over 5-7 tanks.
I don't tune with a temp gun, I just check consistency with a temp gun. The only time I tune to a particular temp is when breaking in an engine.
Orange RC8 with a bunch of crap in it.
largeorangefont is offline   Reply With Quote
Old 08-01-2008, 01:28 PM   #5
Registered User
I wouldn't worry about the temp, mine hit the 105 degree(C) mark, so I didn't use foil either. After about a litre of fuel, the temps came right down, at the two litre mark I was having trouble getting the temps over 70 degrees, that is running it rich around the track.
Loop&Roll is offline   Reply With Quote
Old 08-01-2008, 01:59 PM   #6
Cool, I have put probably 3 tanks through it on the box now just idling. That full throttle, full rich method is interesting. Makes an awful lot of sense. Is that the "Cyrul" method?
Old 08-02-2008, 12:14 AM   #7
vti-chris's Avatar
Try richening the LSN some and increase the idle as well.
Xray/OS/Savox/Sanwa
Axial XR10
Sakura Zero S/Castlecreations
RCO
vti-chris is offline   Reply With Quote
Old 08-02-2008, 12:27 AM   #8
Suspended
Trader Rating: 34 (97%+)
I recently temped my engine with three different temp guages, O'Donnell, Ofna PCR gun and one of those $300.00 ones. Got three different readings. If you are blowing smoke and dumping oil/fuel mix I would be willing to bet you're ok.
FG101C is offline   Reply With Quote
Clutch set up for a X1-CR w/ RB WS7III smb17 Nitro Off-Road 8 07-16-2008 05:23 AM
RB WS7III joshjosh R/C Items: Wanted to Buy 1 09-21-2007 10:16 PM
rb concepts WS7III Zac R R/C Items: For Sale/Trade 4 08-22-2007 08:43 AM
FS---$$$$$ RB WS7III $$$$$$$ Swampracer R/C Items: For Sale/Trade 9 01-30-2007 07:14 AM
NEW RB--WS7III .21 engine Swampracer R/C Items: For Sale/Trade 5 09-14-2006 06:04 PM
