Old 08-01-2008, 01:05 AM   #1
Default V-Spec not reaching temp
So im a good ways into the break-in of my V-Spec(blue head). Every break-in guide i read says to get above 200F as quickly as possible to avoid engine wear. Now i can achieve 200F - 230F quite easily if i rap the heat sink and preheat but as soon as i unwrap the heat sink the temp drops to 150F-180F and its very difficult to get it back up, i can just hit 200F but leaning it out and doing high speed runs... if i lean it any more its going to run well ...lean.
The fuel im running is high quality, probably the best we have here in aus(MMs HB 444), so that's probably contributing to the low temps and the ambient temp is around 70F-80F.
Id love to have these kind of temps on a broken in engine but it kina sucks on one im trying to finish breaking in.
Big thanks for any advice.
Jonro is offline   Reply With Quote
Old 08-01-2008, 02:32 AM   #2
jrwoodchuck's Avatar
I put tin foil around the head and then drive it up and down the street. I'll do 2 runs up and down the street, then come in and check temp to make sure it's ok. After 1/2 gallon I'll take it off and start race tunning it.
Doug
TLR 22/M-11
“Looks like I picked the wrong week to quit sniffing glue.”
jrwoodchuck is offline   Reply With Quote
Old 08-01-2008, 04:25 AM   #3
I keep the foil on the head until break in is finished, that keeps the temps up.
How many tanks have you done so far?
Once the break in is finished the temps should come down anyway.
herb99 is offline   Reply With Quote
Old 08-01-2008, 08:03 AM   #4
Maximo's Avatar
what brand of temp gun are you using ? most hobby grade temp guns are terribly inacurate, so its possible your motor is well past 200 but your gun is reading wrong....
http://www.thenitroshop.com/
Maximo is offline   Reply With Quote
Old 08-01-2008, 04:44 PM   #5
srac cr ot wen's Avatar
Im also having this same problem, my LRP .28 spec3s have never gotten higher than about 180F, normal running temp is like 140-160.
I could also lean it out more, but im scared it will be too lean. I am not producing much smoke when I run at half throttle.
Hey wes.... guess who?!
srac cr ot wen is offline   Reply With Quote
Old 08-02-2008, 06:52 PM   #6
lowey79's Avatar
where are you taking the temp reading from? The will read 10-20° hotter than the top of the colling head....
lowey79 is offline   Reply With Quote
Temp for O.S. V-Spec Truggy007 Nitro Off-Road 6 08-19-2007 08:19 PM
What is best Running Temp on .21 OS V-Spec patrick21x Nitro Off-Road 2 06-13-2007 05:33 AM
FS NIP VENOM SMART/ TEMP (fail safe and on-board temp gauge) factory racer R/C Items: For Sale/Trade 7 07-02-2006 10:49 PM
Raytech mini temp temp gun Art Jensen R/C Items: For Sale/Trade 4 11-19-2005 07:31 AM
NEED HELP! engine wont turn after reaching top dead center even without glow plugs!! tiger266 Onroad Nitro Engine Zone 12 09-24-2005 11:13 AM
