Old 07-30-2008, 04:35 PM   #1
Default Need some help with a Sportwerks Chaos, Newbie.
Bought a Chaos at a yard sale and it looks nearly new. Actually I don't think it ever ran. I checked everything over and it seems to have a few issues.
1) The clutch seems to be slipping a lot. I took it apart and it is installed correctly. The motor really revs but it doesn't go very fast. If I touch the grass with it, it won't move. As far as spinning a tire - Forget about it. Any ideas?
2) It says there is only one adjustment on the carb to richen it or lean it out but there are two screws on it. A small phillips and a larger flat screw, What do they do.
3) When I hit the brakes it shuts the car off, I am assumeing I have something adjusted wrong but what?
Thanks for helping me, New at this & just need to get pointed in the right dirrection.
LK
alwhite00 is offline   Reply With Quote
Old 07-31-2008, 02:11 PM   #2
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Well... several. It could be that the flywheel is slipping on the shaft... but I don't really suspect that at this point.
I would first suspect that one of the center "dogbones" is out, or that there is a problem with the center diff.
Sorry, I don't know what motor you have... MOST carbs have 3 screws... the low speed needle is on the end of the carb slide (the part that moves) The high speed needle is on the fitting where the fuel hose comes in, and the idle adjustment is usually on the back of the carb.
I'd suspect that the idle isn't set, so it lets the carb close all the way and cut it off.
LK
Hope that helps...
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 07-31-2008, 06:18 PM   #3
Brad:
First off, Thanks for the reply. I will check on the shaft slipping but I am pretty sure it's not.
The clutch has 3 plastic "weights" that are on 3 pins on the hub with an extension spring around all three that rides in a hub with a gear on the end that spins the trans in the center. The spring seems really strong and I don't know what RPM the motor spins at but it seems like it would take a lot to get the weights to spin out & contact the drum to get the hub spinning. Not sure what to do at this point but it runs good anyway.
LK
Old 07-31-2008, 06:48 PM   #4
DOMIT's Avatar
Brad:
LK
Ok... the "weights" are your clutch shoes. They have both aluminum and carbon shoes (i.e. plastic) and various weight springs. The carbon shoes engage softer, allowing more slip... aluminum shoes engage harder. Lighter springs make the clutch engage at lower rpm, heavier springs at higher RPM.
If the clutch is engaging... (and it should be... it sounds like it is right) then something else in the driveline is messed up.
Where are you located? Is there a local track where people race? If so, someone there would surely be happy to help.
Based on your description though, I would suspect the center differential is bad, or one of the center driveshafts is not connected (dogbones) but without looking in detail it is hard to say. If you can remove the body and post some pics it might help.
FS/T Sportwerks Chaos. ohmygahitscoby R/C Items: For Sale/Trade 6 08-09-2008 11:17 AM
sportwerks chaos baja.pete R/C Items: Wanted to Buy 3 08-09-2008 12:01 AM
FS--> Sportwerks Chaos RTR--> Like NEW RC10GT69 R/C Items: For Sale/Trade 5 05-01-2008 08:38 PM
FS/FT: Sportwerks Chaos Speedycorvette2 R/C Items: For Sale/Trade 5 04-19-2008 05:41 PM
sportwerks chaos. where to get? cm367700 Nitro Off-Road 2 12-22-2007 07:39 PM
