Old 07-28-2008, 07:46 PM   #1
rcrevolution's Avatar
Send a message via AIM to rcrevolution
Default Severe Glitching on Hyper 8.5pro
Ok before I explain whats going on heres what I have.
Hyper 8.5 pro pretty much stock
Ace DS1313 servo for throttle
Ace DS1015 servo for steering with a servo extension wire
Spektrum receiver
2600mah NIMH 5 cell battery
voltage meter
basic switch for charging and turning the receiver on and off.
Now heres what happens, when starting the buggy I noticed that when I hit the throttle or brake the servo for throttle goes crazy and starts glitching and when I let go it cant center, even the steering sometimes starts acting up, and sometimes it gets to the point where I lose all controle of the servos.
now today at the track I threw caution to the wind when the servos suddenly started working and not glitching at all and ran a tank through the engine without a single problem.
now when the servos start glitching my receiver's green light starts flashing almost like it is picking up interference or losing power.
I had my battery charged through a good charger and it still did it.
only thing I can think of is a bad battery but the battery on the voltage meter under load shows a full 6v...
any ideas?
rcrevolution is offline   Reply With Quote
Old 07-30-2008, 09:14 AM   #2
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
1) Could be a bad switch.
2) Re-bind the TX/RX
3) Check your wires for frayed wires- battery pack AND servos.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 08-03-2008, 01:43 PM   #3
Ok I am lost.
I have a great charger now and I charged the battery properly.
and when ever I turn on the electronics sometimes it works fine, sometimes the led on the specktrum receiver starts blinking and the servos have a mind of their own.
its mainly the throttle servo that glitches but the steering does a little too.
this receiver hasnt been used for more than a few hours total, and I never had this issue on the revo.
the transmitter has full batteries and I already re-binded the receiver and transmitter.
Old 08-03-2008, 02:17 PM   #4
Ok found the problem, I need a new battery.
I am running a ace ds1313 and ace ds1015 servo, whats a good battery to go with? not lipo. that can last me a good 20-30 min?
all I can find is like 1400-1600mah I need like 2000mah at least
Old 08-03-2008, 02:20 PM   #5
wingracer's Avatar
Trader Rating: 23 (100%+)
Is it doing this while sitting on the starter box? Is the glow igniter still attached while all this is going on?
Try ditching the volt watch. I've seen them cause problems in rare instances.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 08-03-2008, 02:20 PM   #6
Integra's Avatar
Mugen makes a 2300....or u can build your own with Energizer 2500's or Duracell 2650's
Old 08-03-2008, 02:22 PM   #7
wingracer's Avatar
deleted
Team Shepherd USA
Old 08-03-2008, 03:07 PM   #8
anyone know if the 2500mah stickman batteries found on amainhobbies are any good?
I have a 2600mah battery I bought from onlybatterypacks.com and it false peaks with in minutes of charging...
I charged it at 0.3A and put the Peak detect at 3mV/C and it false peaks within 30min and with like 90-150mah in it.
Old 08-03-2008, 05:43 PM   #9
could I be having this problem because I am using a AA pack and these servos require a high output?
and 2/3A offer a better output than AA
Old 08-03-2008, 06:21 PM   #10
Integra's Avatar
4 AA cells ? or 5 ? I Hope 5
Old 08-03-2008, 06:43 PM   #11
its a 5 cell battery pack but based off AA batteries.
Old 08-03-2008, 06:54 PM   #12
Dude the Ready 1600 Hump Packs should be ample enough for the job.
I run the same servo's as you and have no problems racing a 45 min main with a 3 minute warm up and usually start warming up 5 mins before that. So they're going for like nearly an hour.
Kev Lewis,
I'd like to thank my personal Sponsors :-AKA Tyres Australia, Ryper Hobbies and Just Hobbies
The Gear :- Associated RC8 B3 powered by OS Engines
Soapy is offline   Reply With Quote
Old 08-03-2008, 07:04 PM   #13
Suspended
what makes you think you need a 2000mah pack?
szakcajaru is offline   Reply With Quote
Severe Radio Glitching Help (Tamiya TA05) AWK Electric On-Road 37 06-11-2007 11:13 AM
**Severe Revo Abuse Video..06/21/05** airmaxx23 Monster Trucks 5 07-03-2005 06:38 AM
**Revo Severe Abuse Video...06/21/05** airmaxx23 Monster Trucks 0 06-21-2005 08:38 PM
Severe Understeering....Help Please jamiekulhanek Electric Off-Road 11 09-27-2004 11:22 PM
Severe Glitching Problem - Please Help! Accord Electric On-Road 2 06-18-2003 01:44 AM
