Old 07-28-2008, 12:13 PM   #1
Default Flywheel spinning on collet, cannot get clutch nut off.
What can I do to get my clutch nut off? If I try to loosen it, it just cycles the engine.
It's a brand new WS7T with Losi clutch and collet. I'm in the process of putting a clutch on it and my guess is that the nut bottomed out on the crank, so I'll have to use a bigger collet... if I can get the nut off the shaft.
Thanks.
Edit: It has blue loctite on it.
Semple is offline   Reply With Quote
Old 07-28-2008, 12:21 PM   #2
You can buy a piston stop tool if you have a non-turbo motor. If you have a turbo motor then I'm not sure, haven't seen a piston stop for one yet.
http://www.amainhobbies.com/product_...oducts_id/5333
Furadi is offline   Reply With Quote
Old 07-28-2008, 12:24 PM   #3
underway's Avatar
Trader Rating: 48 (100%+)
heat up the loctite, take channel locks and hold the flywheel. Take correct nut driver and loosen clutch nut.
underway is offline   Reply With Quote
Old 07-28-2008, 12:28 PM   #4
It's a turbo engine, unfortunately. I can actually turn the engine by turning the flywheel, but the flywheel slips when the engine nears the pinch zone.
Old 07-28-2008, 12:29 PM   #5
If I hold the flywheel while attempting to loosen the clutch nut, the flywheel just spins on the collet, and the loosening of the clutch nut will turn the engine over...
Essentially, I need a way of stopping the engine from turning over so I can loosen the clutch nut.
Old 07-28-2008, 12:32 PM   #6
wingracer's Avatar
Trader Rating: 23 (100%+)
Fill the cylinder with after run oil through the exhaust port and turn the crank to close the port off. The oil won't compress so it will be locked up and you can get the nut off. Just try not to turn too hard on the wrench as this could be hard on the rod. If it is really tight you will need to heat the nut to break the loctite.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 07-28-2008, 12:34 PM   #7
desertbird's Avatar
Take the back plate off and put a tough piece of plastic between crankcase and conrod. I've use a small bic lighter before.
desertbird is offline   Reply With Quote
Old 07-28-2008, 12:39 PM   #8
That worked! Many thanks!
Case closed.
Old 07-28-2008, 12:53 PM   #9
IanWright's Avatar
Location: If i'm not in England i'm in Southern California
Send a message via AIM to IanWright
You can get piston stop tools for turbo plugs.
IanWright is offline   Reply With Quote
Old 07-28-2008, 01:01 PM   #10
BAUSTIN's Avatar
ive ran into this, i just double up a zip tie and slide it in the exaust port to hold the piston....seems to work fine
BAUSTIN is offline   Reply With Quote
Old 07-28-2008, 02:18 PM   #11
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
Where ? I have yet to see one .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 07-28-2008, 02:51 PM   #12
Integra's Avatar
piston locking tools are NOT meant for this application....all you are doing is transfering all that Cranking force to the con rod bushings and crank pin.....a peice of plastic in the backplate is By Far the safest way.
Old 07-28-2008, 02:54 PM   #13
wstuart's Avatar
Trader Rating: 112 (98%+)
Send a message via AIM to wstuart
os makes a pretty sweet piston lockin clamp that goes in through where teh backplate is. - it cost me 15 bucks, but it doesnt stress the internals so bad
wstuart is offline   Reply With Quote
Old 07-28-2008, 03:02 PM   #14
Integra's Avatar
the OS Crankshaft Clamp Piston Locking Tool to be exact.
http://www.amainhobbies.com/product_...oducts_id/8459
Old 07-28-2008, 03:59 PM   #15
A cheaper solution is to remove the backplate and wedge the head of a large zip tie between the crank/rod and the crankcase wall.
If you can't do that rotate the engine past the top of the exhaust port, fill the combustion chamber with after run oil through the glow plug hole and reinstall the plug. This will kill the glow plug, but it will work to get your clutch nut off if done correctly.
Do not use a piston locking tool.. ever.
Make sure you use the Losi collet and not the RB one that comes on the engine. That is probably your problem.
Orange RC8 with a bunch of crap in it.
largeorangefont is offline   Reply With Quote
washer behind the flywheel collet losiracer22 Nitro Off-Road 3 06-25-2008 03:34 PM
Flywheel Collet for MTX almtx3 Nitro On-Road 8 06-21-2008 08:07 PM
flywheel/collet question scrappydoo Rookie Zone 1 05-14-2008 05:56 AM
Picco .12 + NTC3 flywheel. What collet should I use? FREAKAH Nitro On-Road 9 01-23-2007 03:19 PM
Yokomo SG Flywheel and Collet Darkman Australian Racing 8 05-22-2003 08:33 PM
