Old 07-28-2008, 04:43 PM   #16
For the record, I used the rubber engine stopper head from my Losi tuning screwdriver.
Semple is offline   Reply With Quote
Old 08-01-2008, 09:45 PM   #17
TBIRDOWNER86's Avatar
Send a message via Yahoo to TBIRDOWNER86
Default TRY THIS
TRY INSTALLING THE SCREW BACK INTO THE END OF THE SHAFT WITHOUT THECLUTCH SHOES AND CLUTCH BELL....WITH YOUR DRIVER HOLDING THE SCREW TIGHT USE A OPEN END WRENCH TO TURN THE NUT
TBIRDOWNER86 is offline   Reply With Quote
Old 08-04-2008, 08:44 AM   #18
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
I had the opposite problem at the track Saturday... (I was changing the flywheel and couldn't get it to hold the motor so it wouldn't rotate when tightening...) I opened a set of vice-grips just enough to clear the pins on the flywheel, sat the motor on it's backplate, and gave the vice grips a gentle tap with a very light hammer to "seat" the flywheel... then it held so I could tighten the nut. That might work in this case also, if you can't get one of those other methods to work or get the proper devices.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 08-15-2008, 06:06 PM   #19
I am having this exact same problem on my OS VS and Losi 8.
What's the best way to get the back plate off? The bolts come out fine but I am hesitant to try to pry off the back plate.
rav_cherry is offline   Reply With Quote
Old 08-15-2008, 06:23 PM   #20
Trader Rating: 27 (100%+)
Take a pair of channel locks and set them to the size of the backplate square. Then just pry it off easily, working the wrench back and forth and also rotating it. It shouldn't take much force at all. But don't even bother doing it that way...
Just take the manifold off and put two fat zip ties thru the exhaust port above the piston. Has the same effect and will stop the engine from rolling over. It will cut the zipties in half before it causes any damage to the piston or other parts.
Or like said above, fill above the piston with afterrun oil and that will work too. Or even yet you can shove some thing nylon string down the glow plug hole. All these different ways will lock the engine up without causing damage. Providing the clutchnut is not welded onto the crank and you use king kong force to try and break it loose. In which case the end of the crank would probably be the first thing to break anyways.
Team Associated & CRC
Trackstar & Hobbywing esc's
Spektrum radios, GensAce batts, turnigy servos.
Keeping racing fun and affordable with my 8y.o. twins :)
The best track I've raced is the one in my backyard!
jbrow1 is offline   Reply With Quote
Old 08-15-2008, 08:37 PM   #21
Trader Rating: 95 (99%+)
This is typically not a good idea and should be a last resort.
I've seen people break the screws off in the end of the crank and not be able to get them out. I have also seen this fracture the crank where the screw was trying to pull itself in the crank and then it was ruined.
www.rcrcr.com --------> B-Mag free since fall '07
RobbieS is offline   Reply With Quote
Old 08-15-2008, 10:29 PM   #22
nitrothugg's Avatar
Thumbs up
Originally Posted by BAUSTIN View Post
ive ran into this, i just double up a zip tie and slide it in the exaust port to hold the piston....seems to work fine
next best thing to using a piece in the backplate.
nitrothugg is offline   Reply With Quote
Old 08-16-2008, 01:49 PM   #23
Thanks for the help....it worked.
Old 08-17-2008, 01:05 AM   #24
2005 crf 450's Avatar
5 seconds under a propane torch and that locktite wont be a problem. be careful not to burn anything though!
2005 crf 450 is offline   Reply With Quote
Old 08-17-2008, 01:26 AM   #25
If the nut is getting to the end of the threads you need to ad shims between the crank and collet. Ofna has a nice clutch shim kit that has all sorts of shims in different sizes
pdmustgt is offline   Reply With Quote
Old 08-18-2008, 09:57 PM   #26
air8's Avatar
Before trying to re-install the flywheel nut, make sure to clean the threads of the crankshaft and nut. If there is dried loctite in there it will bind things up and sometimes prevent the nut from fully tightening.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
washer behind the flywheel collet losiracer22 Nitro Off-Road 3 06-25-2008 03:34 PM
Flywheel Collet for MTX almtx3 Nitro On-Road 8 06-21-2008 08:07 PM
flywheel/collet question scrappydoo Rookie Zone 1 05-14-2008 05:56 AM
Picco .12 + NTC3 flywheel. What collet should I use? FREAKAH Nitro On-Road 9 01-23-2007 03:19 PM
Yokomo SG Flywheel and Collet Darkman Australian Racing 8 05-22-2003 08:33 PM
