axe rossi cobra/mamba
are there any other carbs that will fit these engines?
novarossi carb should work on there what is wrong with the rossi carb i use one and it work fine.
i have the 3 needle carb and was looking for something less finicky and that uses less o'rings when rebuilding.
Yes, you can use the two needle novarossi carb. If you do
the swap, I'll buy the three needle carb off you. PM me if you want to sell it. |
which novarossi carb will fit?
i think the rossi cobra carb inlet(case throat) opening is 16mm but not sure. |
would the axe rossi SPORT carb work?
it looks the same as the newer COBRA 2 needle version. |
