dumb diff question >
dumb diff question
dumb diff question
Old 07-21-2008, 08:11 PM
mike williams's Avatar
Trader Rating: 45 (100%+)
Default dumb diff question
this thread is taking a turn...the question is a traction question...read the 20th post!!can you over fill a diff? how much should you put in,to the top of gears
thanks Mike W
mike williams is offline
Old 07-21-2008, 08:26 PM
jamminnay's Avatar
i always fill mine to the top off the gears... i let it settle for a minute or two and then top it off if needed
jamminnay is offline
Old 07-21-2008, 08:29 PM
imaxx21's Avatar
yes you can overfill..
thats one of the biggest overlooked problems with leaky diffs.
fill just above the crosspins
imaxx21 is offline
Old 07-21-2008, 11:11 PM
desertbird's Avatar
So what you are saying, and correct me if I'am wrong and just don't understand, you want air in the diff case? I thought that was a bad thing just like a shock? Not contradicting you, just want to understand... let it role.. :-)
desertbird is offline
Old 07-21-2008, 11:19 PM
srac cr ot wen's Avatar
I always thought people said that because it made a mess. thats definately what happened to me, I accidently overfilled.
srac cr ot wen is offline
Old 07-22-2008, 03:42 AM
speedy2's Avatar
remember the opposite gear must go in the diffhousing too till the center...
an overfilled diff can give erratic beheavior of the buggy
as the oil gets warmed up , it expands
and oil must get a way out whatever
it can almost block the diff action in the beginning
speedy2 is offline
Old 07-22-2008, 12:04 PM
Originally Posted by speedy2
remember the opposite gear must go in too till the center...
so now im gonna have to take it all the way apart again and do it properly..
Old 07-22-2008, 12:42 PM
a picture of a filled diff would be very helpful
egobuster1 is offline
Old 07-22-2008, 03:17 PM
thanks i guess im gonna tear mine apart and redo them
Old 07-22-2008, 03:19 PM
1
Old 07-22-2008, 04:23 PM
imaxx21's Avatar
the empty space above the gears is where the other crown gear goes, not air.
if its overfilled the extra oil will just push out past the seals and take the rest of the oil with it...
imaxx21 is offline
Old 07-22-2008, 05:37 PM
how is the pic I posted imaxx?
Im nt 100% sure if thats the proper amount, I actually ended up putting a little more than that, and I also had a bunch of oil that was still on the other gear, its 7000 so its thick and stuck onto it.
Old 07-22-2008, 05:47 PM
imaxx21's Avatar
hard to tell from that angle, but looks ok
get some Naphtha to clean the gears in.
imaxx21 is offline
Old 07-22-2008, 05:49 PM
better?
Attached Thumbnails dumb diff question-diff1.jpg   dumb diff question-diff2.jpg
Old 07-22-2008, 05:51 PM
imaxx21's Avatar
you want it above the crosspins
imaxx21 is offline
