Old 07-23-2008, 04:11 PM   #1
jeff1's Avatar
Default Inferno 777 Clutch Problem, weak material
Does anyone knows a after-market or better clutch than Kyosho?
I broke 2 springs in less than 30min of running.
also noticed that aluminum shoes has short life, because it melt and then the spring scratch in Clutch bell. I tested the Carbon shoe of Kyosho and the problems is the same.
jeff1 is offline   Reply With Quote
Old 07-23-2008, 04:16 PM   #2
Trader Rating: 19 (100%+)
Default 777
I have never had a problem with the kyosho clutch. Do you have the little washers underneath the shoes?
Jmnay_83 is offline   Reply With Quote
Old 07-23-2008, 04:46 PM   #3
khoo's Avatar
I've not had problems with the kyosho aluminium clutch shoes and springs too. I've run 2 x 40min mains without any issues. I put a shim in each shoe.
khoo is offline   Reply With Quote
Old 07-23-2008, 05:43 PM   #4
supralative's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to supralative Send a message via Yahoo to supralative
I have broken one spring, but it was an old used up one.
I have not had any issues with the aluminum shoes or carbon shoes.
I run aluminum now mostly with 1.1 all around or two 1.1 and one .95
After every race weekend though i pull my clutchbell off and sand down
the inside and smooth out my shoes also. I replace springs when the motor begins to get abit weak with snap out of tight turns etc...
Son N.
www.hyperspeedmotorsports.com
www.oklahomanitroclub.com
supralative is offline   Reply With Quote
Old 07-23-2008, 06:44 PM   #5
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
i have never heard of a clutch doing that.. were the springs set down in the groove on the collet??
jamminnay is offline   Reply With Quote
Old 07-23-2008, 07:23 PM   #6
houston's Avatar
Trader Rating: 91 (100%+)
poor clutch maintenance leads to improperly working clutch ! i have had one spring break in 6 yrs. of running kyosho , as far as the shoes go the newer hd 7075 shoes are a touch longer lasting . use two of the .2mm shims under the clutch shoes with a touch of synthetic oil rubbed on them . only use original kyosho clutch springs 1.0mm springs is a pretty good setup for most . make sure to change bearings at very first sign of crunchiness , for longer lasting bearings heat bearing with your heat gun for about 1 min. then drop one to two drops of a full synthetc gear oil viscosity lube. properly shimming clutch bell so it doesn't rub on flywheel and also isn't too far from the clutch bell leaving a total of .2mm of play in clutch bell .
all these things will help you out ,
monty
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 07-28-2008, 08:12 PM   #7
jcad33's Avatar
I didn't want to start a new thread for this so this looks like a good spot to ask. I'm eating clutch bearings like potato chips. I can't go a full weekend without chewing up a bearing. I'm not sure if it not shimmed properly, changed the shims a few times to check and still eating them. Any Ideas??
Batteries.....not just for flashlights anymore. But Nitro is still my Crack!!
jcad33 is offline   Reply With Quote
Old 08-27-2008, 02:15 AM   #8
pitpop's Avatar
A full weekend on a clutch? That is pretty good for a set of bearings. Just depends on how much you run. You can probably get a gallon on a set of bearings if you clean them once.
On the original thread topic, that is a very unusual claim you are making. Kyosho has had the most succesful clutch set-up in the hobby for the past decade. In EVERY case I can think of, when someone asked me to help them with "Kyosho" clutch problems, there was some other third party part in the equation, like a clutch bell, shoes, flywheel, etc. Clutch parts are not interchangeable. Just a couple thousandths different measrement on any single part can cause the problems you are describing.
If you are using a Kyosho clutch, ALL the parts must be Kyosho. There's just too much variance on third party parts.
Cody King's Wrench (and dad :))| Team Kyosho International | Reds Racing Engines | Pro-Line Tires
KO Propo | Byron Fuels | AbsoluteHobbyz.com | Stickit1 Racing | kustomrcgraphics.com
LiveRC.com | OCRC Raceway | codykingrc.com | ROAR Sanctioning Director
pitpop is offline   Reply With Quote
Old 09-11-2008, 07:46 AM   #9
maskedrider's Avatar
Kyosho- OS engine- AVID bearing- Blue thunder fuel- Proline- RC dynamite- Sanwa- RC Art
maskedrider is offline   Reply With Quote
clutch material ioxqq Nitro On-Road 0 03-03-2008 01:27 AM
rs4 3 ss clutch problem . never lift Nitro On-Road 3 01-20-2006 01:27 PM
R40 Clutch Problem Scott S Nitro On-Road 7 12-19-2004 08:16 AM
Please explain differences on Clutch Shoe Material Types 190mph Electric Off-Road 1 10-02-2004 03:24 AM
Clutch Problem B3boy Electric Off-Road 2 04-06-2003 11:20 AM
