Old 07-23-2008, 09:32 AM   #1
Default MBX5R - Spiral Cut Diff Gears - ???????
Hello,
What is the advantage of having the spiral cut diff gears in my MBX5R? Are these gears available for front, center, and rear? Can I use the same cases that's on my 5R currently and just buy the gears from somewhere? Also, could someone please post a link to what I need to buy to make this conversion (usually buy everything from A-Main, so if someone could post links to that site), I would GREATLY appreciate it! Thanks!
Blake
superx421 is offline   Reply With Quote
Old 07-23-2008, 04:56 PM   #2
imaxx21's Avatar
Send a message via AIM to imaxx21
you talking about the MBX5T gears?
those are the spiral cut ones
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 07-23-2008, 05:39 PM   #3
wingracer's Avatar
Trader Rating: 23 (100%+)
Or are you talking about a Torsen full of worm gears.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 07-23-2008, 10:47 PM   #4
maximugen's Avatar
Send a message via MSN to maximugen
what u need is the bevel (small) and crown (large) gears for the front and rear diffs, and a 16/17t clutch bell and a 44t spur gear
Mugen MBX5r - N/R 367 / Sirio bx STi
Mugen MST1 - JP RS12
Losi JRXSR- LRP SPX and Speed Passion 17.5R
HPI Savage - N/R 528
Trex 250
maximugen is offline   Reply With Quote
Old 07-24-2008, 12:32 AM   #5
kd2777's Avatar
Trader Rating: 128 (99%+)
It gears the 5R lower to make it accelerate harder. It is a world of difference. You need the ring and pinon from the 5T to make it work. You will also need a larger clutchbell. Personally you can get away with the 46 spur, the 44 is better, but you can get away with the 46 if need be. I switch between the 46/17 and 44/16 combo depending on track size.
You can buy it from amain but it is a very expensive upgrade. You can come out a lot cheaper getting a complete 5T diff from eBay, plus you get new out drives and everything in the deal. A diff will run about 25 bucks on ebay and a couple 5T pinons about 15, so 65 and you should be done. Amain will run well over a 100.
The spiral cut diffs are also more effecient, you will notice your drivetrain is a lot free-er with the 5T diffs.
kd2777 is offline   Reply With Quote
Old 07-24-2008, 05:34 AM   #6
Default diffs
AWESOME, thanks for the responses. I will begin my search on ebay TODAY. Thanks!
Mugen MBX5R
Airtronics M11
Airtronics 94361 and 94362
SH 8-Port
..........still can't drive though!
Old 07-24-2008, 05:42 AM   #7
Default Diffs
KD,
So just to make sure, you are talking about these three links correct?
http://www.amainhobbies.com/product_...ducts_id/23055
http://cgi.ebay.com/MUGEN-MBX5T-PROS...QQcmdZViewItem
http://www.amainhobbies.com/product_...oducts_id/7503
Just wanted to make sure this stuff will work before I buy. Thanks!
Mugen MBX5R
Airtronics M11
SH 8-Port
Old 07-24-2008, 06:03 AM   #8
TonysScrews's Avatar
I think I may have a 44T spur gear new in package if you're interested? If so, email me at tony@tony1034.com
Best regards,
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
Old 07-24-2008, 07:03 AM   #9
Superx421 I might have a complete setup for sale, complete diffs front and rear, crown gears, pinions, 44 tooth spur gear, and 16 & 17 tooth clutch bells. All of it used maybe a gallon in great shape. Shoot me an email if interested and I will give you a price on it all.
katjim00@att.net
katjim00 is offline   Reply With Quote
Nip bce mbx5r chassis and complete diff setup. jpz_67 R/C Items: For Sale/Trade 9 02-23-2009 07:34 PM
MBX5R Diff - Question superx421 Nitro Off-Road 6 08-14-2008 01:29 PM
Jammin/Kyosho/Hyper 8 Spiral Cut Gears.....NIP wrightcs77 R/C Items: For Sale/Trade 3 01-16-2008 05:02 AM
MBX5R Diff Install Help!!! newbie2006 Nitro Off-Road 5 06-22-2007 12:36 PM
Rear diff gears graham1234 Nitro On-Road 1 07-18-2004 07:51 AM
