Buying a used spektrum receiver, do I need the bind plug?
I have a Spektrum DX3.0 and will be running two buggies off this transmitter. I'm buying a used spektrum receiver to run the second buggy, will I need a bind plug specific to that receiver or do I use the plug that came with the radio? Not sure what the procedure is to bind the second receiver.
Thanks!
Thanks!
Suspended
Location: r.i.p Chiquita - 1993-2008 - "best dog in the world"
If you have saved the bind plug from when your purchased your DX3 it will work fine with whatever receiver you've acquired. They are all the same. Binding procedures? Refer to the manual.
u should just need the plug
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
No plug needed.
1) with the power OFF, hold down the button on the receiver and turn the power on. Light will flash initially. Leave it on.
2) with power OFF on the transmitter, hold down the button on the module, and turn the transmitter on. Light will flash, then go green.
All done.
you shouldn't assume there is no need for the bind plug, the post just says a used RX, if its a used micro RX then you need a plug, any plug will do as was posted they are all the same and not radio/rx specific
if you need the plug the procedure is the same as above, except you plug the bind plug into the batt terminal on the RX and then turn it on, rather than hold the button
both post r correct...for the stock DX3.0 transmitter u use the button and for the micro u use the plug as stated..for the micro receivers you MUST have a bind plug
how can I get the dx3.0 to work with the losi mini receiver. I've tried all suggestions I can find and it will not work. Do I or do I not need a bind plug. If so what exactly am I looking for. I have a pig tale plug that came with my radio that has a switch on it. Is this the bind plug?
if you need a bind plug i have 5 so let me know ill just pop it in a letter and send to you. just send me 42 cents in the mail LOL
