Old 07-22-2008, 08:33 PM   #1
sachoppers's Avatar
Default Left front Tire wear
I Have a hot bodies truggy and buggy..both with rapid left front tire wear, center to inner tire wear.
There both set up about the same...-2.0 camber front and rear, +2.0 rear toe,-2.0 front toe..both front and rear arms lvl.
Any Ideas what i could set different.
JAMMIN X2 CRT
Go .21 3p rsepc
Go femca 0801
sachoppers is offline   Reply With Quote
Old 07-22-2008, 08:59 PM   #2
wes95_z28's Avatar
Its the torque steer when you stab the throttle, chances are you are still running the stock grease in the diffs.
When you stab the throttle, the rear end squats and due to the twisting force on the center front driveshaft your right front tire is getting shoved into the ground and your left front is getting lifted ever so slightly.
To fix this is simple: Use diff fluids to stop this and make the vehicle accelerate harder.(buggy) Try using 7000 in the center, and 5000 in the front 2000 in the rear. I am not sure which Wts. to use for your truggy.
Wes
Kyosho 777 WC w/ big bores, RB S5, ACE 1313 s., Air 357 t., JP-3
HPI Savage X SS, Axial .28, Hitec 5645 Steering servo
Nitro TC3, O.S. .18 CV-R
Associated RC18T, Brushless, Lipo
wes95_z28 is offline   Reply With Quote
Old 07-22-2008, 09:17 PM   #3
Jesse Robbers's Avatar
Send a message via AIM to Jesse Robbers
Does the track you run at have a right hand turn onto and off of the straight and/or also maybe more right hand turns than left hand turns? Or are all or most of the more open/higher speed turns right hand turns? If yes, then that is why your left front is wearing mroe than the right front tire.
Sponsored by: O.S. Speed, KO Propo, Sidewinder, Tekin, Thunder Power, Lunsford, Skipgear.com, Fioroni, Avid R/C, GMK Supply, Competition Heat, Dialed Inc., LiveRC.com, DE Racing, CIG2O, ANDROID Nitro Runtime Calculator App
Jesse Robbers is offline   Reply With Quote
Old 07-22-2008, 10:29 PM   #4
sachoppers's Avatar
fluids have been changed..to 5000 front 7000 center and 3000 rear.
And there is a right hand turn onto a straight...and most of the right turns are high speed turns..
Is there anything that can be done to offset this?
3 races = 1 new tire..
JAMMIN X2 CRT
Go .21 3p rsepc
Go femca 0801
Old 07-22-2008, 10:35 PM   #5
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Is it possible your getting to much lift on the left tire coming out of a left turn. That will eat a tire up. You may just have to set the droop. Just a thought.
UN4RACING is offline   Reply With Quote
Old 07-22-2008, 11:01 PM   #6
sachoppers's Avatar
Ahh..so set droop on the front..more on on one side,hmm.
That sounds like an idea there.
It kinda looks like the left front does lift on the straights on very hard accel..
JAMMIN X2 CRT
Go .21 3p rsepc
Go femca 0801
Old 07-22-2008, 11:39 PM   #7
shizzytrx450's Avatar
Send a message via AIM to shizzytrx450
Damn that sucks
shizzytrx450 is offline   Reply With Quote
Old 07-23-2008, 07:54 AM   #8
Setup changes will not do much for the tire wear unless if you make a large enough change that will make your car handle like poo everywhere else. The best thing to do is just rotate the tires.
Old 07-23-2008, 03:01 PM   #9
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
NOT more droop on one side, it will jump strange. More droop overall.
Also, I only WISH tires would last me 3 full races... but our track is abrasive if it is not wet. lol
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 07-23-2008, 03:02 PM   #10
DOMIT's Avatar
There is wisdom in this post...
Old 07-23-2008, 05:14 PM   #11
rotate ur tires after every race to try to wear them equal or try getting equal run times on each part
www.nitrojunction.com
The #1 site for all your nitro needs
egobuster1 is offline   Reply With Quote
Old 07-23-2008, 05:14 PM   #12
sachoppers's Avatar
I see..Ill just have to live with it then..im fairly new to the hobby.I didnt realize tires went so fast.
and ill keep them rotated after each run..
thanks guys
JAMMIN X2 CRT
Go .21 3p rsepc
Go femca 0801
Old 07-23-2008, 05:18 PM   #13
sachoppers's Avatar
Originally Posted by shizzytrx450 View Post
Damn that sucks
real helpfull post..thanks
JAMMIN X2 CRT
Go .21 3p rsepc
Go femca 0801
Old 07-23-2008, 06:40 PM   #14
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
i just wish a set would last the whole raceday!!
jamminnay is offline   Reply With Quote
Old 07-23-2008, 07:29 PM   #15
ya ull soon understand why people carry huge tubs full of tires new and used..i cant afford a million sets of tires so i learn to rotate them and keep them looking good
Reducing Tire Wear Riketsu Nitro On-Road 28 02-08-2008 09:36 PM
Tire wear RKeasler Electric On-Road 1 09-02-2006 05:30 PM
Foam tire wear...front to rear Jeel Electric On-Road 8 10-08-2005 11:36 AM
tire wear question? stumper Electric On-Road 11 05-27-2004 09:26 AM
Tire wear and tuning... rpnick Rookie Zone 15 09-08-2003 12:19 AM
