Old 07-18-2008, 10:55 AM   #16
Suspended
Originally Posted by cjtamu View Post
These things are expensive and nobody wants to get stuck with a $200 paperweight.
Andybody that starts a thread proposing using a pullstart is IMO one way or another not going to shell out the money for a decent mill, and will most likely end up with a paperweight no matter what anyone says. So we can suggest all the good this or that and ultimately he's more likely going to go where he can get the most bang for his initial buck regardless of the longterm, or even short term, ramifications.
rocket-mtrsprts is offline   Reply With Quote
Old 07-18-2008, 11:09 AM   #17
wow thanks guys for all the great info, I do have a novarossi P5 that came with my buggy but one side that mounts to the motor mount broke off but still hold it on there firm and I don't know if I should still use it that was and if I did I would want to put a new piston and sleeve just to be safe.
I really don't ever plan on racing my buggy so i wouldn't need a racing motor. I guess I just want to get a motor that has plenty enough of power in all ranges if that's even possible. Done the road if I ever do decide to race I can get a race motor
I would like to keep the price at $200 or under for now.
Here is a pic of the motor I have and the piece that is broke,
eagle_talon is offline   Reply With Quote
Old 07-18-2008, 11:10 AM   #18
Thumbs up Motor for Losi 8ight Buggy
Learning to tune .21 size motors..
While the OS motors mentioned above/below are great motors, I would suggest a motor that can handle a learning curve. The OS motors cant handle getting hot very many times, but the RB Concept motors being made of harder material hold up very well as learning motors. They also make great race motors.
I suggest:
RB S5 L2G with a JP-3 pipe. This is a good race package at an economical price.
Expert level race motor:
RB WS73 L2G also works well with JP-3
You can get a good deal on many motors here:
http://www.airlandhobbies.com
Inside_Line is offline   Reply With Quote
Old 07-18-2008, 11:12 AM   #19
Ha ha ha. That's why I said $200 paperweight and not $500 paperweight. I am starting the hunt for a new big track mill for my 8ight though. Can you tell me which one is the best? ha ha ha ha ha.
cjtamu is offline   Reply With Quote
Old 07-18-2008, 11:24 AM   #20
P5 is an excellent engine. Probably no reason to get a new piston/sleeve unless that one's been scarred or has been pinched already several times. Having it squeezed is about $20 plus shipping. You might be able to find someone with a crankcase for it, or I've seen wonders worked with JB Weld. Might hold, might not. That's a Novarossi, but a Rex or Top crankcase should work. P5 has had at least 2 crankcase versions though so you'd need the right size one if you replace. If you can have the p/s squeezed and either find a used crankcase or repair that one and get it running it's probably worth it. If the bearings are bad or it needs a new rod then probably just better off with a new engine.
BTW, is that an RD Logics pipe? I have one of those in a pit box somewhere.
Old 07-18-2008, 03:23 PM   #21
most of the engines I have used for my 1/10 scale stadium trucks were pull starts so thats why I mentioned that . my last few were OS .18 cvrx's in my rc10gt's and 3.3 in my Jato
Now if I decide to race I can always get a motor specific for that but in the mean time I just need one that I can have fun with and has plenty of power.
Old 07-18-2008, 04:01 PM   #22
GH Racing's Avatar
I'd say the OS V-spec .21
GH Racing by Golden Horizons. Buy Direct At: WWW.GHHOBBY.COM
FOLLOW US ON TWITTER NOW: twitter.com/GH_Racing
High Quality Machined Aluminum Parts and Accessories. Vancouver, Canada.
GH Racing is offline   Reply With Quote
Old 07-18-2008, 04:46 PM   #23
Trader Rating: 19 (100%+)
To be honest with you, now I am a racer and since you said you wont race I say just get a Mach 427 off Ebay they come with a drill starter and will have all the power any BASHER will ever need. Dont spend hundreds of dollars on something that doesnt need to cost that much. But I will tell you this "unless there is something seriously wrong with you, the 1st time you go to a race track you will be hooked". And then you can spend $300++ on a mill. LOL And I know a few guys that race with that mill in their monster trucks.
TT MT4G3 all tricked
TTST4G3 MT4ed out
JR servos Hitec servos. Gens ace lipos KO radio.
malik is offline   Reply With Quote
Old 07-18-2008, 05:01 PM   #24
so it will have plenty of power in the low and upper RPM's
sounds interesting
Old 07-18-2008, 05:26 PM   #25
C.Poh's Avatar
Trinity Ex-Tech .21 base motor for 299$ at Amainhobbies and get a box bump start good for both bashing around and racing yeah you can buy a cheep motor for like 130 $ with a pull start but why waist the money when you can kill 2 birds in one stone like the person above said once you race your gonna luv it and want to race more and more and these new trinity motors are lovely i have just over 2 gallons in mine and its beautiful from top to bottum with smooth power everywhere,check out the ex tech thread nothing but good news from all the ex-tech .21 versions from base to fully modded ,but whatever you decide have fun and good choice on vehicle losi to win the 08 worlds lol
MUGEN SEIKI
AKA RACING
JS ENGINES
AIRTRONICS
C.Poh is offline   Reply With Quote
Old 07-18-2008, 08:08 PM   #26
kd2777's Avatar
Trader Rating: 128 (99%+)
FWIW Harley, I currently run the GRP, MAX POWER M5B, and the ORION CRF...I recommended the Dynamite and Sportwerks line of engines because he mentioned a pull start type engine which means the OS VG or similar, I recommended a motor that I am more than confident that will feel his needs. I've seen too many of the Sportwerks and Dynamite motors at my local track run, for several gallon, to think they are a "piece of crap".
If the p5 has decent compression I would say fix that one first. Since it is the older P5 it is the case design that uses the 14x25.4x6 rear bearing. I would post up on the WTB thread that you are looking for an older style p5 case and I figure someone has one laying around that they will send you on the cheap. You may have to pick up a couple bearings, but the rear cost about 20 bucks and the front one (7x19x6) for about 15 (that is for TKO ceramics off of AMAIN). Then all you need is a starter box. I like the OFNA chrome top that was mentioned, but I donít much like it with the 8ight. You need to do some modifications to make it work right. As much as I think the box is a piece of junk, the Losi box that is made for the 8ight might be your best bet since you have no experience with a bump box. It comes with the pegs already set up for the 8ight. What I donít like about the box is the motors are on the weak side. The only thing you have to keep in mind is when you break in a new motor always use a heat gun, it will not only take stress off the engine, but it will also save your starter box motors.
If you do decide to rebuild the p5 and have any questions about getting it apart/rebuilding or questions in general shoot me a PM or email.
kd2777 is offline   Reply With Quote
Old 07-19-2008, 05:36 AM   #27
OS also makes an electric start verson of the VG. Not sure about the Sportwerks or Dynamite but they might also.
Losi 8ight/8ight T one piece engine mount Cameron R/C Items: For Sale/Trade 4 04-08-2008 10:52 AM
Losi 8ight-T Truggy w/Engine & Pipe fastzach R/C Items: For Sale/Trade 13 09-09-2007 12:50 PM
Best Engine (speed/torque/fit) for Losi 8ight? tbone555 Electric Off-Road 32 05-14-2007 07:18 PM
losi 8ight what engine ? papadocks Electric Off-Road 18 05-09-2007 01:52 PM
Brand New Losi 8ight RTR w/engine and radio smoothie R/C Items: For Sale/Trade 3 05-02-2007 06:28 PM
