Old 07-17-2008, 11:42 AM   #1
srac cr ot wen's Avatar
Default Should a new 120$ servo be making this noise?
http://www.youtube.com/watch?v=0paqQ8r5ygo
Its a brand new JR 9001. This was the first time it was used.
Hey wes.... guess who?!
srac cr ot wen is offline   Reply With Quote
Old 07-17-2008, 11:49 AM   #2
My 9100t only sounds like that when it's strained. You might want to check that your steering linkage isn't binding.
Furadi is offline   Reply With Quote
Old 07-17-2008, 12:06 PM   #3
I dont think it is, what exactly do you mean by that?
also, my steering it only on 70% too.
Old 07-17-2008, 12:16 PM   #4
wingracer's Avatar
Trader Rating: 23 (100%+)
I'm at work and can't listen to the video but servos usually do make some noise, especially when strained at their limits but can make all kinds of noises even when not strained.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 07-17-2008, 12:17 PM   #5
Serpent720's Avatar
Yeah, my 120.00 HiTecs in my buggy make that noise, they have since I bought them over a year ago. But don't have any problems with it.
Serpent720 is offline   Reply With Quote
Old 07-17-2008, 12:18 PM   #6
jrwoodchuck's Avatar
For the most part it's ok. I've been using digital servos in helis for 10 years now. We call them "nervous servo's" because of the noise they make. Just make sure the end points are adjusted correctly. To do this put youre radio on the EPA or ATV screen (depending on radio) Turn the wheel all the way to the right and make sure that it's not binding, or pulling it too far. Then back it down 3%. Then do the same for the left. Sometimes the endpoint numbers can be different.
Doug
TLR 22/M-11
“Looks like I picked the wrong week to quit sniffing glue.”
jrwoodchuck is offline   Reply With Quote
Old 07-17-2008, 12:18 PM   #7
Yeah, I have two of them... a 9100s and 9100t and both do that. One on the steering and one on the throttle/brake.
Listening to your video your 9100 acts just like mine. Buzzing at the ever so slight force against it. You can take your finger and slightly touch the servo arm to make that noise happen. When your turning your wheels sometimes it's quiet at neutral and sometimes it makes a buzz. Just means there is very slight pressure remaining on the arm.
If there is absolutely no resistance, and I mean NONE, it will go quiet just as
your video shows.
I think your servo is fine.
BTW, the sound acutally helps me set my end points.
Don Duct is offline   Reply With Quote
Old 07-17-2008, 12:24 PM   #8
your video shows.
allright, what you described there is bang on.
I just wasnt sure if that was 'healthy" for it or not.
thanks alot guys.
/thread
Old 07-17-2008, 12:25 PM   #9
ya thats perfectly normal...my hitec 5995 in my revo makes a ton of noise and it seems the more torque the servo has the more noises it makes so thats perfectly normal just make sure your EPA's are set right otherwise that 120 dollar servo will burn out very quickly
www.nitrojunction.com
The #1 site for all your nitro needs
egobuster1 is offline   Reply With Quote
Old 07-17-2008, 12:29 PM   #10
EPA is 70% for both
thanks
Servos making noise Darth Smoke Nitro Off-Road 26 08-06-2008 10:17 AM
airtronics 94758 making noise icantdrivetc5 Radio and Electronics 1 06-13-2008 05:56 PM
Breaks on savy making strage noise! silacomalley Monster Trucks 2 08-12-2005 11:53 PM
servo noise nitrosaurus Nitro On-Road 18 05-08-2003 01:03 PM
