Old 07-16-2008, 10:29 AM   #1
Default much more charger issues????
I have a MUCH MORE charger for my reciever packs, I keep getting a false peak on both my packs when I try to charge them. They are 1700 packs and i can only get 300 into them. If anyone can help. I would deffinetly appreciate it.
higgs2ca is offline   Reply With Quote
Old 07-16-2008, 10:37 AM   #2
DavidR's Avatar
Trader Rating: 97 (100%+)
Send a message via Yahoo to DavidR
Try Setting the Charge Rate at a little less than 1C.
1C = Capacity of the battery. 1700MaH battery would equall a 1.7 Amp "C".
I would try charging at 1 Amp.
See if that helps.
- David
DavidR is offline   Reply With Quote
Old 07-16-2008, 10:43 AM   #3
What DavidR said. Except if the packs are really dead, you might even have to go lower. I just did several for a buddy that had been sitting for a long time. I had to do both Rx packs at 100 mah for 5 to 6 hours before I could bump the charge rate up. I keep a regular wall charger around for things like that. It doesn't peak detect, so I can just put the batteries on for awhile and not worry about false peaking, then just switch them to my charger later.
cjtamu is offline   Reply With Quote
Old 07-16-2008, 10:43 AM   #4
I have been charging at 1.2a, so I will try it at 1. Thanks for the help.
Old 07-16-2008, 11:48 AM   #5
RC Dad's Avatar
Trader Rating: 26 (100%+)
Send a message via MSN to RC Dad
Are you sure the packs are discharged? If not, 300 may be all they'll hold. We can usually go through 3 heats and a 10-minute main and only use 450 mAh out of a 1200 mAh pack
GV2 Pro, XXX4G+, Blitz SCT, CRC GenXL
RC Dad is offline   Reply With Quote
Old 07-16-2008, 11:55 AM   #6
Doh! Good point. If the packs are full charged and have actually peaked then they should feel a little warm when finished.
XXX-S issues rcketch Electric On-Road 4 07-20-2008 05:27 PM
Old issues? sk8rdylan13@yah Electric On-Road 2 07-27-2006 09:05 PM
Some issues with the Lst sjlam Monster Trucks 7 11-06-2005 05:50 AM
help my 3 pk has issues papadocks R/C Tech Site Forum 6 04-26-2005 07:34 PM
HELP!!!!!!!!!!! charger issues wilson_bryant Electric On-Road 6 04-07-2003 04:00 PM
