Old 01-28-2009, 09:19 AM   #46
Trader Rating: 53 (100%+)
sweet .....pics of the rear?
Rick Hess
Tekno RC--Protek RC
R&C Hobby shop Clarksville TN
RCP Customs
rkhess is offline   Reply With Quote
Old 01-28-2009, 01:38 PM   #47
-R2-'s Avatar
Originally Posted by MadRacer View Post
OK did another track test and was sooo much better.
Still had a lot of steering but was controlable.
Did a few more changes and am getting my spirits back.
Jumps really nice. Changes direction really quick. Has a heap of on power steering as well.
Only complaint is the back stills snaps out under power out of a corner.
The track was very loomy and will be better on race days i say.
Thanks to all that helped and Pm'd me.
Cheers.
Mark.
4k-4k-2k
35wt front and rear 1.4 holes in the pistons I did all of the holes on the pistons
stock sway bars,no cuts
#3 holes on the shock towers
outside hole on the rear lower arm
2 degrees rear camber/3 degrees rear toe
SOAR SEIKI 998,Truggy, Buggy and Electric
Flashpoint Fuel/Savox/
-R2- PAINTS/PRO-LINE RACING/AIRTRONICS
-R2- is offline   Reply With Quote
Old 02-02-2009, 08:07 AM   #48
I think the stock guide in the rear is just right if you are using the fiber brakes
Genius is offline   Reply With Quote
Old 06-23-2009, 10:06 AM   #49
has anyone heard anything on the new arms
nastynate is offline   Reply With Quote
Old 06-23-2009, 11:44 AM   #50
They're supposed to be +1mm longer giving a total of +2mm width to the front, and stronger. they're more flat, instead of having that bump where the shock mounts as well.
they seem to hold up well on Kortz's car
team2zon is offline   Reply With Quote
Old 06-23-2009, 11:47 AM   #51
does anybody know when they will be available?
Old 06-23-2009, 01:29 PM   #52
Well im not happy with mine at this stage.
Cant get a set up on our loose tracks. My 8.5 was so much better.
NO REAR Grip is my problem and have tried everything.
Will try some more things next test day. Not even worth trying to race as its too much off the pace.
Hi!
I had the same issue:
- 5-4-2 diffs
- Front upper arm inside upper position
- Front upper arm longer position
- User thinner rear stab (2,2mm)
It will be great, faster then your 8.5.
BR
Aron
Aron1 is offline   Reply With Quote
Old 06-24-2009, 07:11 PM   #53
juzza99's Avatar
A friend of mine went from the hyper 8.5 to the hyper 9 about 3 or 4 months ago,and i can definatly say that he was quicker with the old car than the hyper 9... He has all sorts of dramas getting it too turn on tight corners.
juzza99 is offline   Reply With Quote
Old 06-24-2009, 11:42 PM   #54
has he tried
JOEY POWELS setup
Front:
Inner upper arm: 1
Outer upper arm: 1
Upper shock location: 2
Toe: Out 1.5 deg
Camber: -0.5 deg
Sway bar preload: flush with ends
Stock sway bar ground in center
Piston: 2-1.2/2-1.4
Oil: 37.5wt Losi
Rebound: 5mm
Shock length center to center: 105.5mm
Diff: 3000cst Mugen
Rear:
Inner upper link: 1
Outer upper link: 1
Upper shock location: 3
Lower shock location: 2
Hub location: 2
Hub spacing: Hubs back
Toe: 2.5
Camber: -1 deg
Anti squat: 2 deg
Piston: 4-1.4
Oil: 35wt Losi
Rebound: 5mm
Shock length center to center: 126.5mm
Diff: 3000cst Mugen
Center: 5000cst Mugen
Brake Bias: Front, 40% Rear, 60%
Rear ride height slightly higher than front
Replace stock servo saver spring (too soft) with Mugen MBX5T/or crt servo saver spring
there are also new sway bars out so u dont have to do any grinding
Rick Hess
Tekno RC--Protek RC
RCP Customs
Old 06-25-2009, 08:16 AM   #55
jamiekerr14's Avatar
Really, I cant believe that.. I got my 9 about a month ago, after running my 8.5 for 1 year. Its 100% better in every department.. apart from durability.. maybe but it turn's on a dime compared to the 8.. I cant really fault it.. that is very odd he's quicker with the 8.. but a decent setup goes along way!.. very odd.. But, Mine is setup for my local track, As the top british Hobao driver.. John Hazlewood's runs there alot.. So have a advantage.. but yea very odd to hear that..
Xray XB4
Supported By:
RC Disco
jamiekerr14 is offline   Reply With Quote
Old 06-25-2009, 08:48 AM   #56
Hi! which servo do I need for hyper 9?
sakis is offline   Reply With Quote
Old 06-25-2009, 01:00 PM   #57
-R2-'s Avatar
Ok I just wanted to report on arms since this has been an issue that everyone talks about, we have been testing and sending back arms back and forth to fix this problem, sorry that it's taking so long but to see what we have been doing to destroy an arm dropping a new car over 8ft. off the grond on the corners smashing them with hammers,twisting, freezing,sun heating then smashing them and have had interesting results. yes it's been taking a while but there have been bumps in the road to be sent back and forth to Hobao and Ofna let alone one of the bumps is Tim Bump himself analyzing the arms and the stress factors that he sees in the arms, I'm telling you i have changing arms left and right over and over again just so they can destroy it for me to take it apart and put it back to gether, it hurts to see a fresh car with no chassis scrathes just being dropped from the air and bouncing all over the place tires cut and new Proline wheels getting bent and never turning some RPM's but there's just a few more fixes and test before they become a running change.
Old 06-25-2009, 01:05 PM   #58
-R2-'s Avatar
Oh and with all this testing I've come up with another turnbuckle for the upper arm, use part number 36861 the Jammin upper turnbuckle, it's longer and will fill the gap in the arm so it doesn't blowout at the end of the turnbuckle, also another upper arm is also comming which is thicker but i'm still using the 36861 part to better the combo, now if you want to use the outside whole for a different setup, then you would need a new set of arms and use the rear turnbuckles from the Hyper 9 on to the new arms, that set up fill the gap compeletly but that not work on the inner hole that's why you would need two sets of arms.
Old 06-25-2009, 01:12 PM   #59
mechanic77's Avatar
-R2-, would it be possible for you to let us all know when the new arms are out? I suppose most stores will just rotate out the old stock into the new design, but maybe Nitrohouse can hook us up with the new design ones when they are available. Thanks, Andy
Durango DEX210, Tekin RS, SMC 7.5, Savox 1258TG
Durango DEST210R, Tekin RS, LRP 8.5, Savox 1256TG
Ofna Nexx 8, Tekin RX8/1900kv, Hitec 5955TG (FOR SALE)
mechanic77 is offline   Reply With Quote
Old 06-25-2009, 02:43 PM   #60
-R2-'s Avatar
I don't always get to see the stock come in and sometimes items are on backorder and are filled right away so when they come in they don't give word sometimes I find out later when someone calls or responds online, like 29128 cnc front brace I just found that out and it's been here for a week or 29130 cnc 17mm shock cap set complete these items are in stock right now.
HoBao Hyper 10 Nitro Touring Car - THREAD paul73rc Nitro On-Road 10 01-12-2012 06:44 PM
Official Hyper 7 Thread TTR:EB4 Nitro Off-Road 35 08-22-2011 08:19 PM
GV REX-X Pro or HoBao Hyper PBS PCR Pro! Undies Electric Off-Road 8 03-19-2006 02:46 PM
Official Hobao GP4 thread Cartman Nitro On-Road 41 07-25-2004 08:30 AM
