Old 07-16-2008, 11:01 AM   #16
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 48 (100%+)
This is the one I mentioned. Probably the same internals as the one above.
http://www.walmart.com/catalog/produ...uct_id=7081179
Jon Carlson is offline   Reply With Quote
Old 07-16-2008, 12:12 PM   #17
I like my little 4.8V cheapo one I bought at Big Lots for $15. Can't remember the brand. I like it 'cause at 4.8V it turns slowly enough that I don't have to worry about stripping plastic. I always break the screws loose and do the final tightening by hand anyway, so once they're started it takes them out just fine. Oh yeah, and it has the little LED light like Domit's does so my old eyes can see what I'm doing!
cjtamu is offline   Reply With Quote
Old 07-16-2008, 01:07 PM   #18
Savage6151's Avatar
Default this on works great and 29.99 to boot!!!!
Skil 2348-01 4.8V Twist Screwdriver
4.8v of power
In-line compact 2 position design in one tool
Direction of rotation is indicated by the on-tool LED directional arrows
Light up dark or dim work area with the built-in work light
Comfortable, ergonomic soft grip handle for user comfort
Better control allowed with the comfortable 2 finger trigger
Rechargeable battery with included charger
Specifications: Skil 2348-01 4.8V Twist Screwdriver
Battery -- Integrated NiCd
Voltage -- 4.8
Chuck Size -- 1/4" Hex Chuck
Certifications -- cULus
Weight -- 14 oz.
The Skil 2348-01 Includes:
Charger 2 Driver bits
FT RC8
O.S. V-spec
Team CRC
Team Associated
Team CFX Paintworks
Sponsors:
G2 Designs....Sick Paint for your RIDE
Troyer25.... Slick Designz
Savage6151 is offline   Reply With Quote
Old 07-16-2008, 01:13 PM   #19
Trader Rating: 19 (100%+)
I have the black and decker too, only wish they made one with a clutch.
Dirt's for racing,asphalt's for getting there!
pooldoc is offline   Reply With Quote
Old 07-16-2008, 04:16 PM   #20
TonysScrews's Avatar
I get emails all the time from my Tony's Screws customers asking for recommendations on tools. The cordless driver you want is at Lowe's for only $50. It is the Hitachi. It comes with two Lithium batteries, has two speeds and also a variable clutch. It is by far the best bang for the buck!
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
Old 07-16-2008, 05:22 PM   #21
imaxx21's Avatar
Send a message via AIM to imaxx21
and it fits easily into the tool box
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 07-16-2008, 08:35 PM   #22
Djballen's Avatar
+1 on the Hitachi
But on Tips I would get some eds tools
http://edsracingproducts.com/categor...-Tips-Sets.htm
Djballen is offline   Reply With Quote
Old 07-16-2008, 08:48 PM   #23
Originally Posted by RobbieS View Post
The new Dremel Lithium Driver has variable trigger speed. Most others are only a on-off with a high and low gear.
I needed a new dremel also so I picked up the package deal and I absolutely love it.
+1 on the dremel.
http://www.lowes.com/lowes/lkn?actio...-01&lpage=none
It has variable speed trigger, Li-ion and enough power to drive a 4" drywall screw but if money if is no object Tom fyz is correct, the bosch is the best.
It adds removable batt, light, more power and $60 but it is SWEET!!
"It's like his brain is running a 64p spur and 48p pinion, sometimes it will engage and work but mostly it just makes a terrible noise"
Stallard is offline   Reply With Quote
Old 07-20-2008, 11:27 AM   #24
I was researching this same thing about a month ago. For the drill/driver, I narrowed it down to the Bosch Litheon 10.8V Pocket Driver (http://www.boschtools.com/Products/T...spx?pid=PS20-2) and the Milwaukee 12V Drill Driver (http://www.milwaukeetool.com/webapp/..._192142_192137). In spite of the name, both are 10.8V nominal with 12V peaks.
I chose the Milwaukee because the motor locks when not in use. Comes in handy when doing the final tightening.
For the bits, I went with MIP after hearing about how long the tips last. My Losi set is already starting to round off after only a few months of use. I had also heard negative things about the Ofna bits. The only issue is that each bit costs $12.
I have several EDS Racing tools and they rock. I wish I had known they had tips because they retail at $22 for 4 bits.
mthird is offline   Reply With Quote
Old 07-20-2008, 11:33 AM   #25
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Don't know what you heard, but I have been using my ofna bits for 3 years.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 07-20-2008, 12:31 PM   #26
tony montana's Avatar
Trader Rating: 65 (100%+)
I dont know the name brand but I got mine from autozone. I pnly paid 10 bucks for it. Doesnt have a clutch or anything but I think its only 4.8 volts. Makes it perfect for my cars, cause its a slow speed.
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
Old 07-20-2008, 12:47 PM   #27
you are right Tony. That slow driver goes hand in hand with your speed on the track.
eltorito is offline   Reply With Quote
Old 07-21-2008, 08:04 AM   #28
d4man's Avatar
Wow guys thanks for all your input. I narrowed it down to the Black and Decker LI-3000
The greatest trick the devil pulled was convincing the world he didn't exist...
I always thought I had a pretty good imagination, but it turned out to be just my imagination.
NOT a member of Team Terribles!
d4man is offline   Reply With Quote
Old 07-21-2008, 06:49 PM   #29
bring it on javier. lol, bout time you get back in rc
Old 07-22-2008, 12:47 AM   #30
Anyone know whether the Hitachi charger can be plugged into 220 volts. Cause in Asia 220 is normally used. Thanks
Genius is offline   Reply With Quote
what bits for powered screwdrivers coryip Electric Off-Road 6 12-15-2007 09:22 PM
Integy metric and SAE nutdrivers and screwdrivers ManicRC R/C Items: For Sale/Trade 4 10-07-2007 10:41 AM
hex tool bits for batt. powered screwdrivers? Valentin.H Chat Lounge 8 06-28-2007 09:14 PM
Corless Digital Servo Like New Futaba S9550 racer34v R/C Items: For Sale/Trade 2 03-04-2007 08:30 AM
Best Tools: Hex and Nut Drivers, Screwdrivers ... etc. Mike Schumacher Team and Company Discussions 24 06-14-2006 06:09 AM
