Old 07-15-2008, 07:35 AM   #1
LosiSuperTruck's Avatar
Trader Rating: 18 (100%+)
Default ST-RR maintenance?
Just wondering how often you guys change certain parts on your ST-RR. I have been putting allot of time on my truck and haven't really replaced anything that hasn't broke. I'm thinking I should put in new diff cups and bearings about now, but maybe I'm wrong? I got 10 or more race days on this truck, plus practice days.
LosiSuperTruck is offline   Reply With Quote
Old 07-15-2008, 10:35 AM   #2
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
the strr is a very durable truggy.. as long as you are cleaning and inspecting the diffs and other parts you will be fine..
jamminnay is offline   Reply With Quote
Old 07-15-2008, 11:00 AM   #3
Suspended
do it however you want
tried to help, I'm out
rocket-mtrsprts is offline   Reply With Quote
Old 07-15-2008, 11:25 AM   #4
Originally Posted by rocket-mtrsprts View Post
That's sort of the endless pit of lack of maintenance people get into, and then seemingly have something go wrong every race day or every heat.
Personally, I go through and replace things as part of routine maintenance before they're broken ~ worse case scenario, I've got a used spare diff (rebuilt and clean) and other bits and pieces I can throw at the truck in an emergency or as needed to get through a weekend.
I have had the truck torn apart a few times, changed oils, etc. But the parts look OK. So you just randomly replace stuff?
Old 07-15-2008, 12:25 PM   #5
Suspended
Old 07-15-2008, 01:03 PM   #6
Oasis's Avatar
Trader Rating: 36 (100%+)
Unless your rich I would not replace parts that are not worn just because..When my CVD's start getting slop, when bearings have to much play, excessive slop in suspension parts..I will change/replace then..Kyosho parts are not cheap and I dont have a huge RC budget, I do keep spares and I dont let stuff get excessively worn..I guess it's a judgement call..
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 07-15-2008, 03:23 PM   #7
This is kinda how I do it right now.
I think using rocket-mtrsprts method it would be cheaper to just buy a new truck and sell the old one. And I wrong? I mean i can get them for $600 new, I'm sure I can get $250-$300 for my used roller. I am thinking I am right.
Old 07-15-2008, 04:16 PM   #8
Oasis's Avatar
..so if someone has a different idea..
Old 07-15-2008, 04:35 PM   #9
Wow, didn't see that coming.
Old 07-16-2008, 06:14 AM   #10
Suspended
Old 07-16-2008, 06:16 AM   #11
Suspended
nope, no worries, his choice
Old 07-16-2008, 08:37 AM   #12
You are funny
Old 07-17-2008, 10:42 AM   #13
Well I went ahead and did a complete tear down last night. To say I am impressed would be an understatement. These diff cups and gears all looked brand new after I cleaned them out. Not a single sign of notching!!!! Man my Losi buggy will notch the diff cups after 1 race day. This ST-RR has at least 10 race days, 4 of which had 30 minutes mains.
So all I did was give it fresh oil, nothing else looked in need of replacing or was sloppy with the exception of the rear hubs and a few bearings.
Old 07-17-2008, 11:36 AM   #14
bill marchant's Avatar
Trader Rating: 229 (100%+)
Send a message via Yahoo to bill marchant
Same here have about 2 gallons on my ST-RR I tear it down after every race No worn parts the Moly ring/pinion holds up real nice after every run I clean and rebuild them. the only parts I have been replacing is the o rings and retaining clip on the rear BB shocks other than that I haven't dipped in 2 any spare parts I bought except the front arm that I broke when i hit the rail once Solid Truck
bill marchant is offline   Reply With Quote
Old 07-17-2008, 12:21 PM   #15
Oasis's Avatar
Yea..My ST-RR is the same..Very little wear, bearings showing signs of slop but not any more than any other truggy I've had.
One-Way maintenance stiltskin Electric On-Road 10 02-01-2008 03:23 PM
what maintenance?? bigboss Nitro On-Road 3 10-09-2006 08:58 PM
Zen and the art of RC maintenance..... Mabuchi540 Electric On-Road 69 03-31-2005 02:20 AM
maintenance? cHckbOY5 Nitro On-Road 2 06-08-2003 06:22 AM
maintenance nitrosaurus Rookie Zone 7 03-18-2003 07:42 PM
