Old 07-14-2008, 01:20 AM   #1
Trader Rating: 7 (89%+)
Default Cleaning Engine How Often?
How often do you guys open up and clean your engines? Lubing Etc?
oggietiu is offline   Reply With Quote
Old 07-14-2008, 08:38 AM   #2
i clean mine every 2 to 3 gallons...
some dont do much of anything to their engines and just clean the top of the piston off with some very fine steele wool, i think its 0000 is what you will want to use. but after cleaning i clean it totally out with some isopropyl alcohol or some type of nitro blast cleaner, clear it out with an air compressor. add some after run oil and slap it back together.
i also do more extensive cleaning methods, but i do not think its needed. I remember cleaning some of my engines with the above method and I got 10 gallons...i guess I just get bored at times who knows lol
AVID Bearings- The best bearings hands down
Upgrade-RC- Keeps the bling going
BCE Speed- Holds it down
Tonys Screws- Keeps you from getting screwed
Byrons Fuel- Makes the RC world go round
Jesse is offline   Reply With Quote
Old 07-14-2008, 08:39 AM   #3
Steve Walters's Avatar
I clean my motor (And whole buggy) after each race. But I do a complete motor tear down, inspection, and internal cleaning after each gallon of racing.
OR at any point I think there is something going out in the motor...
"CVR" Central Valley Raceway (Madera, CA)
Team "WTF" Racing member
TEAM BCE (Product/Field Tester)
X-Ray 808 (Active Diff)
BCE 8X8 Pro Chassis
OS Speed (XCustoms Head Mod)
Hitec 5995TG (S&T)
M11 & Spectrum.
Steve Walters is offline   Reply With Quote
Old 07-14-2008, 08:13 PM   #4
Thanks Guys. I usually break it down and clean it after a gallon too. Sometimes less if I think it is needed.
I can get a grip on what to use to clean them. Now I am using a diuted mixture of Simple green to clean it and soft terry cloth. After that I give it a blast of compressed air make sure its really dry, Relube the bearings and slap it back together.
Some use kerosene, some use denatured alchohol. But I like the cleaning power of simple green. However I need to get it wet. Is this Bad?
Old 07-14-2008, 10:23 PM   #5
wes95_z28's Avatar
I truthfully try to take my motor apart as little as possible. I really only take it apart when maintanece is needed, I feel the less you take it apart the less chance of any foriegn particles getting into it. I have gotten to the point where I do not even replace bearings or conrods anymore. I have had stock bearings and conrods in these highend engines last the entire life of the piston and sleeve. Usually over 10 gallons.
But before I get flamed, yes I have been burned by a bearing going out, or a conrod breaking early in a motors life. But for the most part, if it aint broke dont fix it.
Wes
Kyosho 777 WC w/ big bores, RB S5, ACE 1313 s., Air 357 t., JP-3
HPI Savage X SS, Axial .28, Hitec 5645 Steering servo
Nitro TC3, O.S. .18 CV-R
Associated RC18T, Brushless, Lipo
wes95_z28 is offline   Reply With Quote
Old 07-15-2008, 05:32 AM   #6
Trader Rating: 38 (100%+)
Same with me. I open it up and inspect it after each race day.
A habit I got into from when I used to race TZ250s...
JQ Products "Le Car" - 3 of them. Primary, back-up, and spares car
Bunch of "classic" Schumachers
Tamiya - Leopard 2A6, Tiger 1
HPI - Blitz
bushyar15 is offline   Reply With Quote
Cleaning 0.21 engine brianr34 Nitro Off-Road 6 04-20-2008 10:30 AM
Cleaning engine Orfeous Nitro On-Road 33 06-05-2006 08:21 AM
Cleaning an Engine? LosiSuperTruck Nitro On-Road 1 09-04-2005 04:15 PM
Cleaning an Engine LosiSuperTruck Electric Off-Road 1 09-04-2005 02:25 PM
engine cleaning tip rcabj Onroad Nitro Engine Zone 3 04-18-2004 07:34 PM
