Old 07-14-2008, 09:05 AM   #16
This is just the info I was looking for. I like the idea of a fast break in, especially if it helps maintain compression and power for a long time. I think I did a halfway decent job on my Thunderquake as it still feels like it has great compression, but I'm always open to new ideas.
Can someone post up a link to an oil additive to the fuel or what kind of oil to get if its a non-R/C specific off the shelf item?
Duratrax Thunderquake: Sold
New R/C coming soon
racer12306 is offline   Reply With Quote
Old 07-14-2008, 09:39 AM   #17
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
I personally like to add Sig castor oil to the fuel if its race blend (11% or less oil) or I run some Omega 10% fuel for like the first few tanks or up to 1/2 gallon.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 07-14-2008, 09:57 AM   #18
Thanks.
How much do you add? I noticed it said on Sig's website 5oz per gallon to bump the oil 3%. So i figure that will be 1.25oz for a quart for a 3% boost.
New R/C coming soon
Old 07-14-2008, 01:39 PM   #19
Originally Posted by Davidka View Post
One important thing is missing from the above suggestions. Use a heat gun to pre-heat the engine to 160+f (the $15 ones for applying monokote to airplane models works great). If you do this you will find the engine will start very easily and not get stuck at TDC while you're trying to get it going the first couple of times. That's just the convenience though, the real benefit is that it relieves the con rod and bearings of the beating that a brand new, tight piston/sleeve puts on them the first couple of runs. Also, wrap the head in tin foil. This will allow you to easily achieve the 200+f temps that you are looking for while still running the engine rich, thus passing lots of oil through the engine, further protecting the bearings, con rod bushings and piston.
yes, youre right, I cant believe everyone forgot to mention that!
I always heat it up with a hairdryer (approx 130f).
new to rc cars is offline   Reply With Quote
Old 07-14-2008, 06:36 PM   #20
i dont add anything to my fuel, i break in all my mills using the same exact fuel i race with.
AVID Bearings- The best bearings hands down
Upgrade-RC- Keeps the bling going
BCE Speed- Holds it down
Tonys Screws- Keeps you from getting screwed
Byrons Fuel- Makes the RC world go round
Jesse is offline   Reply With Quote
Old 07-17-2008, 09:57 AM   #21
Is there an easy way to tell when the piston is at the bottom of the stroke without pulling the glow plug?
New R/C coming soon
Old 07-17-2008, 10:01 AM   #22
turn the flywheel lock to lock and return to the middle
clarksib is offline   Reply With Quote
Old 07-17-2008, 10:04 AM   #23
<---brain fart
that makes sense
New R/C coming soon
Old 07-17-2008, 11:56 AM   #24
slaytanic's Avatar
Trader Rating: 20 (95%+)
When you get it to BDC them mark the flywheel with a sharpie or something. Helps find it later. I do that on my new mills before I mount them.
Team Epic
Team Terribles~Answer RC~Fastlane Graphics~Torco Race Fuels
XB808 Mamba Max Pro/Tekin 1900kv RC-monster mount and tray 4s
XT8 Hobbywing 150a esc/2000kv combo KILLER! Full rc-monster e conversion. 4s
slaytanic is offline   Reply With Quote
Old 07-17-2008, 10:50 PM   #25
Trader Rating: 18 (100%+)
Send a message via Yahoo to infanterene
I idle one tank and then run 1/2 gallon really rich infront of my house or in a big parking lot. I start at a 1/4 throttle and work my way up to almost full throttle also leaning it out little by little. When Im done its about 90% race tuned.
Ever since doing it this way my motors have all lasted atleast 9.5-10 gallons before loosing pinch.
RC America - Team X-Ray - Maxys Fuel
infanterene is offline   Reply With Quote
Old 07-18-2008, 01:24 AM   #26
TTR:EB4's Avatar
Originally Posted by new to rc cars View Post
I dont know if this is the best, but its what I do.
first 2 tanks, kind of rich and let it idle. up to 10% throttle.
second tank, dont change settings, leave it kinda rich, then drive it around slowly at no more than 25% throtle.
4th and 5th tank, drive it at no more than 50% throttle.
6th tank, drive it at arund 75% throtle.
7th tank, drive it at 100% throttle, but still be easy on it. short WOT blips on the trigger.
10+ you should be able to do WOT for 3 or 4 second bursts, by this time you can lean it out a little and start to adjust the engine.
Im missing the part where you let it cool down in between tanks.. or are you not supposed to let it cool between tanks? thats the only part im not 100% sure about.
someone please correct me if im wrong on any of this, im getting a new engine very soon and am going to break it in like this, wouldnt want to do anything wrong.
thanks
+1, thats what i did, motor screams
The Masher! >.<
TTR:EB4 is offline   Reply With Quote
Break In jlinds Nitro Off-Road 5 07-26-2008 09:44 AM
break set up? roy862 Nitro Off-Road 3 02-29-2008 05:45 PM
New O.S. eng break in? kcsoa22 Monster Trucks 2 09-02-2005 09:40 PM
Break In Dirtfreak15 Monster Trucks 7 05-26-2005 04:30 AM
MT 12 break in Fastburn Nitro On-Road 14 03-28-2003 03:54 AM
