Old 07-09-2008, 03:17 AM   #1
mike williams's Avatar
Trader Rating: 45 (100%+)
Default werks b7 pro question
i have a werks b7pro motor and a werks 2013 pipe and was wondering if any one knew what change could be made to give the motor more bottom end. this motor has more than enough top end and would like to get more bottom end. thanks in advance.....
LOSI MF2 ....... too fast for me!!!!!!!!
mike williams is offline   Reply With Quote
Old 07-09-2008, 03:33 AM   #2
you could try a 13 tooth clutchbell.
cm27456 is offline   Reply With Quote
Old 07-09-2008, 04:00 AM   #3
Trader Rating: 26 (100%+)
Send a message via AIM to cheesecake
1.1 clutch springs
cheesecake is offline   Reply With Quote
Old 07-09-2008, 02:44 PM   #4
Trader Rating: 14 (100%+)
are you sure you're not just spinning the wheels? I ran that combo and it was retarded torquey.
o.s. power is offline   Reply With Quote
Old 07-09-2008, 04:21 PM   #5
losimark's Avatar
I am no pro at werks motors but I know someone that is sponsored by them he runs the same setup with the 1.1kyosho spring and the mugen composite shoes with the ofna clutch bell.
The ofna clutch bell is a little larger than most others allowing more time for the shoe to work.(more stall rate)
P.S.make sure your clutch shoes are going the right direction.
http://www.fthobbies.com
www.fthobbies.com
losimark is offline   Reply With Quote
Old 07-09-2008, 04:32 PM   #6
1: it's in a losi 8 buggy
2:14 pinion/4 spur
3:i don't think im spinning the wheels..just flat for about 10 feet or so
4:running a fironi clutch with standard spring
any suggestions are greatlly appreciated.....
Old 07-09-2008, 04:36 PM   #7
losimark's Avatar
do you have the heavy spring for the clutch? If not that is your problem I know this from using that for a year or so.
www.fthobbies.com
Old 07-09-2008, 04:46 PM   #8
yes, i do have heavy springs for the clutch. are you saying that i should use the heavy springs in the clutch. i was thinking that the heavy springs would give it less torque due to the higher rpm to engage the clutch. am i wrong or does it make sense? thanks Mike
Old 07-09-2008, 05:25 PM   #9
infernoman2008 is offline   Reply With Quote
Old 07-09-2008, 05:55 PM   #10
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
I had a JP-1 on mine and it was just STUPID fast on the bottom...
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 07-09-2008, 06:00 PM   #11
losimark's Avatar
think of it like a real car when you dump the clutch. more stall to a certain point will give you more off the line power. you just have to find the power band.
www.fthobbies.com
Old 07-09-2008, 06:00 PM   #12
Davidka's Avatar
Trader Rating: 75 (100%+)
First thing to do is change to the 13t clutch bell. Also, you might just not have a good balanced tune. Maybe too lean or rich on the bottom? This engine/pipe is well known to be a power house so aggressively clutching it should not be necessary, especially with a buggy as light at the 8ight. Try the stock 8ight clutch with two alloy/gold spring and two composite/green spring shoes. That might be the best clutch I have ever used.
Old 07-10-2008, 12:35 AM   #13
I ran an 053 pipe on mine in a MBX5T and it made tons of power, especially on the low end. I could clear jumps with a short run up that almost no one else could. It made more power than my C6BB by far. I tried the 2013 pipe but didn't like it as much so I stuck with the 053. Mine lasted for 10 gallons, ran awesome the whole time. I think you should definately go to a 13t bell, and possibly get some help with your tune. If you go too lean the engine really drops off fast in power. The balance between high and low can be tricky to get, but it stays in tune once you find it. So be patient and work on your tune. Pick up an 053 pipe if you don't have one because they work great on pretty much every motor.
NPlayer is offline   Reply With Quote
NEED HELP WITH WERKS B3 moeman Nitro Off-Road 5 08-24-2008 05:25 PM
F/S Werks .28 b7 Pro Phoenix82 R/C Items: For Sale/Trade 0 03-07-2008 07:16 AM
Werks TL.21 B3 Crashhole R/C Items: For Sale/Trade 3 02-18-2008 12:33 AM
new werks b7 party_wagon Electric Off-Road 13 05-16-2007 08:11 PM
WERKS B3 icemandolmite Electric Off-Road 4 02-25-2007 12:11 PM
