Old 07-08-2008, 07:38 PM   #1
Trader Rating: 52 (98%+)
Default losi 8
what is the trick to filling shock mine all rebound differently should they rebound at all? also rear diff cups keep going out wich is problem cuz evertime it does ring gear and pinio gear are shot that's almost fourty bucks happen three times in last weekend have hd diff cups coming will that fix it? also shock shafts keep pulling out even after being lock tited in any suggest o and I set my drop limters to what the three times also last weekend
mixedguy is offline   Reply With Quote
Old 07-08-2008, 07:54 PM   #2
cornerspeed's Avatar
If your shock o-rings are good, fill up the shocks with oil all the way near the top. Get all the air bubbles out by slowly moving the shaft up the body without pulling it down. When it gets near the top without going out of the oil, Slowly pull the piston down and turn slightly, a little, to let air out from under piston. This will allow big air bubbles to escape. You want to avoid tiny air bubbles as this will take longer to disapate.
Once all the air is gone, move the piston to near top about 1/4 from top of oil. Set the bladder on top(some oil will come out). then pull the shaft down about 1/8 to 1/4" (this will suck the bladder to the body). Then screw the cap on. then tighten without letting the shaft to pressure down ie hold the shaft from moving down. The shocks should be perfect every time.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 07-08-2008, 07:58 PM   #3
The diff cups? Meaning the plastic housing for the side and spider gears? If that is the case, is the slots for the pins notching? It will happen with these diff cups. But I never had them take ring and pinions out. I guess if the diff explodes then it can do it. The HD diff cases will help your problem. Ids it the front? rear? or center? having problems?
Just to be sure what you are talking about, what is the part # your having a problem with?
Donny Vinkemulder
TLR Driver
Old 07-08-2008, 07:59 PM   #4
Say again please.
Donny Vinkemulder
TLR Driver
Old 07-08-2008, 08:03 PM   #5
Thread the small screw thru the piston 1st. Clean the threads of the screw and the shock shaft with cleaner. Aplly thread lock to the threads in the shaft and assemble.
If you apply the threadlock to the screw, then thread it thru the piston, then the threadlock wipe away from the threads of the screw.
Donny Vinkemulder
TLR Driver
Old 07-08-2008, 09:11 PM   #6
kd2777's Avatar
Trader Rating: 128 (99%+)
Also once put together let them stand abit before putting them back in the car. I always let mine sit over night, but sometimes you can't do that. If it is a rebuild, I think the biggest key is to make sure all the oil is cleaned out of the shaft and off the screw.
As far as shock rebound goes. I always built mine to slightly rebound, I built them basically the way described above. But last year at the midwest gas champs at CRCRC Mike Truhe was in our tent and one of the guys I was with ask him about building shocks, he built one for us. He filled it to the top, put on the bladder and capped it. It rebounded dam near like it had a spring on it. He claimed that is the way they build them. I've tried it and I liked it, it made the car react alot faster that is for sure.
kd2777 is offline   Reply With Quote
Old 07-08-2008, 09:33 PM   #7
Default thanks
yea I am talikg about diff housing when it gets notches in it.it was rear I am putting hd hosing in all three diffs and as far as shocks did truhe let air bubbles out or bleed shocks or just fill put blatter on and tighten down?
Old 07-09-2008, 11:38 AM   #8
Default more ?
wich clutch springs will give u most punch also what sway bar is what thickness i have all of them but dont know what color is what thikness can not find info
Old 07-09-2008, 12:12 PM   #9
Integra's Avatar
the stiffest clutch spring is Silver.......u should be able to tell which is which from matching up the ends on the bars.
Old 07-09-2008, 12:27 PM   #10
Akhor's Avatar
When you say
Do you mean that he pulled the shaft to teh bottom, filled the oil to the very top level of the shock then added the bladder and put on the cap?
Akhor is offline   Reply With Quote
Old 07-09-2008, 01:33 PM   #11
Integra's Avatar
thats the way i do it......Fill the shock up.....work out the bubbles....make sure its full enuff so there's NO air between the blatter and oil and cap it with the piston at the very bottom.......my shocks normally rebound pretty close to each other.....1-2mm's is no biggie imo
Old 07-09-2008, 02:26 PM   #12
Akhor's Avatar
Good to know. Thanks.
NEW! Losi Starter Box, Mamba Max ESC, Losi Mach 427 Engine, Pipe, Air filters, etc! JeffEmbracedDC R/C Items: For Sale/Trade 3 05-12-2008 06:55 PM
BRUSHLESS LOSI TYPE R W/ SPEED PASSION GT/13.5 AN ORION LIPO 4800 I NEED A LOSI 8 DENNIS STORTI R/C Items: For Sale/Trade 1 05-04-2008 08:42 AM
Losi BK2 losi Hauler bag LRP Charger losi oils jr 2 radio Brian Miskolczi R/C Items: For Sale/Trade 15 04-15-2008 09:54 AM
Mike Truhe TQ's & Wins The Losi Winter Series With GRP/Losi NEW VIDEO! CarCrazy Nitro Off-Road 6 02-04-2008 10:48 PM
*LIKE NEW LOSI 8IGHT BUGGY AND TRUGGY, 3PKS w/FASST, NINJA .21, 21-5,LOSI BOX, * MattP R/C Items: For Sale/Trade 12 09-16-2007 11:33 AM
