Old 07-08-2008, 07:09 PM   #1
Default front bearing issues
Hey All,
One of my OS Speeds may have a leak in the front bearing. I noticed it to have decreased power and increased temps my last race and when putting after run oil in the motor it did seep srom the front bearing. Just wanted some thoughts.
Thanks,
Kane
rcdepot.us
nxgraphics.ca
Kane-o is offline   Reply With Quote
Old 07-08-2008, 07:15 PM   #2
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
the bearing is probably going bad.. how many gallons does it have on it?
jamminnay is offline   Reply With Quote
Old 07-08-2008, 07:43 PM   #3
Davidka's Avatar
Trader Rating: 75 (100%+)
The bearing could be going bad but keep in mind that the front bearing seal is not air or water tight. If there is an excess of oil in the engine it can leak out the front bearing. If the bearing is bad it should be easy to tell. Remove the plug (better yet, the piston and sleeve too) and turn the crank. Also wiggle the crank side to side to see if any play has developed.
Old 07-08-2008, 11:21 PM   #4
2 gallons on the motor, but I did put an excess of after run oil in the motor which could explain the issue.
Thanks,
Kane
rcdepot.us
nxgraphics.ca
Old 07-09-2008, 03:19 PM   #5
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Excess after run oil always seeps out of front bearings. Second, if you run that engine rich or on high oil content fuel, it will sweat oil from the front bearing and rear case cover. Once you run lower oil fuel or lean it to race tune, that disappears. Now as for your engine, it should run strong at 2 gallons, unless somoething has gone wrong. I haven't had or seen a dud Speed yet so far that I have tuned, but there can be issues with any engine.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 07-09-2008, 03:59 PM   #6
losimark's Avatar
If you clean the motor with any liquid or spray when its dirty sometimes the dirt will seep in and ruin the seal , bearing , piston & liner.
http://www.fthobbies.com
www.fthobbies.com
losimark is offline   Reply With Quote
Old 07-10-2008, 08:21 AM   #7
slow coach's Avatar
best to check bottom of case, i had what i thought was a leaky front bearing and it was running hot turned out it was a small hairline crack in the bottom of the case.
sorry should add this was the standard v-spec not the speed but symptoms sound similar.
Kyosho MP9TKI2 soon to be TKI3, Novarossi, SMD, GM Racing, www.grccc.org
a great wife and lovely kids
what more can you ask for
a win on the lottery :D
slow coach is offline   Reply With Quote
os18tz front bearing spudly12 Nitro Off-Road 1 09-11-2008 11:53 AM
V-Spec front bearing issues Jonro Nitro Off-Road 35 09-06-2008 10:04 PM
Airleak front bearing??? J.Gonzalez Onroad Nitro Engine Zone 8 08-12-2008 03:13 PM
Front Bearing Jason Halvorson Nitro Off-Road 12 08-12-2007 04:09 PM
front bearing nitro maxx90 Electric Off-Road 3 10-30-2006 07:56 PM
