Old 07-08-2008, 03:18 AM   #1
TC3ElectricGuy's Avatar
Default Receiver Help
New to all of this and just need someone's help... plz .
i have a JR 135 40mhz receiver. but it doesn't appear to want to work. i've used the on/off switch and plugged the battery pack in directly, but it doesn't want to go.
my battery setup is 2x2, but i don't think this should make a difference.
i tested the battery out on my plane and works fine (diff receiver, diff transmitter), then i plugged in a channel, battery and used the car transmitter, but nothing happened..
so i've tested this out with stock JR servo's (analogue) and a brand new digital servo and nothing.
Would it be fair to say my receiver is dead, or could it be the crystal, or transmitter.
thanks
TC3ElectricGuy is offline   Reply With Quote
Old 07-08-2008, 06:02 AM   #2
Trader Rating: 95 (99%+)
Did the receiver come with the radio as a set or did you pick up the receiver individually?
Are you in the US? 40 mhz is not allowed in the US (technically) and more than likely your transmitter is not on 40 mhz which will make them in compatible.
Either way need a little more info. What transmitter and what frequency is it on?
www.rcrcr.com --------> B-Mag free since fall '07
RobbieS is offline   Reply With Quote
Old 07-08-2008, 06:12 AM   #3
Australian 40mhz.. channel 61. both tx and rx have a crystal.. unfortunately because this is my first car i don't have any other crystals to try. and there are no lights on the receiver to tell me that i have putting power into it.
Old 07-08-2008, 11:52 PM   #4
tkhoo's Avatar
Trader Rating: 45 (98%+)
Send a message via MSN to tkhoo
Just make sure you put in right 40MHz band crystal. Something like 40.xxMHz on both your Tx and Rx. And the "-" on the rx batt should be located on the outside of the rx case. You can check online on this too. If still same mean your rx might be bad.
1/8 scale buggy: HB D8, Truggy: 1/12 Jammin CRT.5
Radio: Sanwa M8 power by Sanyo Eneloop, Charger: Hot Power 6016
http://pgrcclub.blogspot.com/
tkhoo is offline   Reply With Quote
Old 07-09-2008, 01:21 AM   #5
everything is working now... still not sure why it didn't want to work. i'll keep an eye on it.
<><> FS/FT Spektrum 3PK Module and Pro receiver for Futaba Fasst receiver only! <><> ffpm46 R/C Items: For Sale/Trade 5 08-06-2008 09:36 AM
Spektrum 3PK Module and receiver - 1 Extra receiver fire929 R/C Items: For Sale/Trade 0 12-18-2005 03:17 AM
3PDF radio,XXL receiver,TEKIN chrome receiver FS LTO-B R/C Items: For Sale/Trade 12 12-01-2005 06:40 PM
Futaba 3PM w/ Receiver, M8 Module w/ Receiver wendellc1 R/C Items: For Sale/Trade 2 07-06-2005 08:27 AM
backlit M8 Ver III + RX311 receiver + VB servos + Receiver pack + wall Charger flyingfox R/C Items: For Sale/Trade 6 04-16-2005 02:10 PM
