Old 07-07-2008, 04:18 PM   #1
DPowers's Avatar
Trader Rating: 79 (100%+)
Default novarossi p5xs
i got one of these motors and with the pipe i am running i am getting around 6 or 7 minutes on a tank and that is with a jp-4 pipe and with a 053 pipe i am barly getting 5.5 minutes the motor runs good but i cannot lean it to much are it will start bogging i am running a mc59 plug and using cen2 byrons 25 peercent fuel.
DPowers is offline   Reply With Quote
Old 07-07-2008, 04:33 PM   #2
imaxx21's Avatar
Send a message via AIM to imaxx21
so whats your question?
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 07-07-2008, 04:37 PM   #3
DPowers's Avatar
my question is i need more fuel mileage and if any one else is using these motor what kind of fuel mileage are they getting. and what plug would be the best for the motor.
Old 07-07-2008, 04:50 PM   #4
imaxx21's Avatar
what carb restrictor?
59 is a pretty hot plug, id drop to a mc8 or an OD99
-Crash
Old 07-07-2008, 04:54 PM   #5
DPowers's Avatar
i am thinking it is a 7 it is the one that come with it and i am going to try the od99.
Old 07-07-2008, 08:12 PM   #6
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
P5XS comes with #6 glowplug. I don't think your bogging is lean, as I have ran several P5X engines, and then bog if its too rich. If they're too lean, they run hot, but they will still produce power, unless it overheating, then the power will decrease, but not bog from my experience.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 07-07-2008, 09:25 PM   #7
I'm running a p5xs in a mugen mbx5r. I get great mileage about eight minutes
per tank. I am using an novarossi 9886 pipe,short manifold,Odonnell 20% and
a mc8 medium plug; the engine runs great with good power.
The mc59 is an hot plug mainly for small block engines using 20% nitro or less.
If are using 25% nitro with stock head shims, I would try a medium plug like
the stock novarossi #6 or an Odonnell #99. Hope this helps
topcat-lll is offline   Reply With Quote
Old 07-07-2008, 10:01 PM   #8
PowerHouse's Avatar
Trader Rating: 66 (100%+)
I am also running my race ported P5XS in an RC8 with a 7.25mm insert, a JP1, RB Concepts 8 cold plug and TQ 30/12 and I am averaging 9-10 minutes on a tank depending on temp, humidity and of course driving style. You should be getting at least 7-8 minutes with the stock 8mm insert. Not sure where you run, how you drive and how you tune motors but that should be your target number.
PowerHouse is offline   Reply With Quote
Old 07-07-2008, 10:14 PM   #9
wild gopher's Avatar
Trader Rating: 39 (100%+)
i get about 8.5-9.0 mins on mine using a novarossi C5 plug and a JP3 pipe in my 8T. Im moving to a novarossi 9853 pipe soon and hope to get near 10 mins
RCtech - Filling me with adult drama since 2003
wild gopher is offline   Reply With Quote
Old 07-07-2008, 11:24 PM   #10
Trader Rating: 26 (100%+)
Send a message via AIM to cheesecake
i ran the p5xs with a od99 with a msr1005 pipe and was averaging about 8 minutes a tank running byrons or werks fuel
cheesecake is offline   Reply With Quote
Old 07-08-2008, 08:46 AM   #11
TommyD's Avatar
I run mine with the 59 and jp-2 pipe. I got about 9 mins with the stock restricter and then put the 6.5 resticter in it and get 10 minutes easy. INSANE power and about 210 deg. I put the smaller restricter in to tame the bottom end. I have a happy trigger finger so I'm usually not good on fuel runs anyway. Next race I'm going to try mixing up carbon and alum. shoes to take away some more bottom.
Impulse-RC
Team Caster 09'
Torco Fuel
2009 Bigg Johnson Hobby Stock!!
TommyD is offline   Reply With Quote
Old 07-08-2008, 09:43 AM   #12
slidejob26's Avatar
I am running the P5XS in an MBX5R with a Dynamite 007, OS8 plug and Nitrotane 30%. I get right about 8 min at 225-230 degrees. Air temp is usually mid 70's. Thats at our outdoor track. At our smaller indoor track I get about 9 min running the same set up.
Scott
PERFORMANCE RC, Burlington WA 360-755-7084/360-755-9464
slidejob26 is offline   Reply With Quote
Old 07-08-2008, 11:43 AM   #13
run the p5xs in my mbx5r using the RB. no.6 PLUG JP3 PIPE stock cab restricor no work sone on the engine i get between 10 and 12.5 mins runs and run 10 min qualifers without a fuel stop.
adz06 is offline   Reply With Quote
Old 07-08-2008, 11:51 AM   #14
kd2777's Avatar
Trader Rating: 128 (99%+)
p5xs comes with a 8mm red carb insert.
Nova c-6, msr 1005 gives me over 8 min, not sure where you are going wrong cause our track is dang near full wood all the time.
kd2777 is offline   Reply With Quote
Old 07-08-2008, 01:04 PM   #15
Poppin Fresh's Avatar
Avoid the JP-4 pipe as it is known to be a fuel hog. JP-3 does well instead. Best pipe is the 9886 pipe with Novarossi long smooth flow header. 8 minutes minimum with blistering top and massive bottom end.
Poppin Fresh is offline   Reply With Quote
NovaRossi P5XS for sale Briguy R/C Items: For Sale/Trade 3 05-02-2009 05:32 AM
Novarossi P5XS and 30% nitro looneytune Nitro Off-Road 3 07-28-2008 10:48 AM
NIB Novarossi P5XS PowerHouse R/C Items: For Sale/Trade 1 06-09-2008 07:13 AM
Novarossi P5XS motors NIB PowerHouse R/C Items: For Sale/Trade 3 02-25-2008 09:59 PM
Novarossi Sale Plus 21-7 & P5XS JamminFan R/C Items: For Sale/Trade 19 12-14-2007 08:00 AM
