Old 07-06-2008, 07:50 PM   #1
lowey79's Avatar
Default OS Speed silicone filled crank
I'm just wondering how the silicone will react to after run oil? Is there a special type for filled crank engines? Will 3in1 oil make the silicone swell?
Thanks for any help...
lowey79 is offline   Reply With Quote
Old 07-06-2008, 07:53 PM   #2
wingracer's Avatar
Trader Rating: 23 (100%+)
I have heard that transmission oil based after runs (all the red ones) will swell the filler but I never had a problem with it. Just to safe I switched to Mobil One synthetic motor oil.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is online now   Reply With Quote
Old 07-06-2008, 08:52 PM   #3
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
If you can, you can use the Mugen engine oil. I personally try to keep oil off the filler at all time though, as least not letting it soak in the crank filler area.
They can be repaired though if needed. I had mine redone by Maxy from Maxy's fuel.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 07-06-2008, 09:37 PM   #4
German Muscle's Avatar
im pretty sure WD40 is what is bad for it. Almost all after run oils out there are fine and wont hurt it. I myself use novarossi assembling lube though and there is no need to any lubricant to be on it.
German Muscle is offline   Reply With Quote
oil filled shocks for micro desert truck. jrwoodchuck Micro and Mini Scales 2 01-21-2008 10:38 PM
Crank Shaft from OS SPEED V-SPEC atomapapa R/C Items: For Sale/Trade 12 10-02-2007 08:13 AM
RC18T OIL FILLED SHOCKS BigGooFBall R/C Items: For Sale/Trade 4 09-17-2007 08:35 AM
Team losi Mini T oil filled shock nip bmoney R/C Items: For Sale/Trade 1 01-22-2007 10:46 AM
Oil Filled Shocks for Tamiya M-03 Mini wademcgee R/C Items: Wanted to Buy 0 07-15-2005 09:48 PM
