Old 07-06-2008, 04:12 PM   #1
freestyles's Avatar
Trader Rating: 14 (100%+)
Arrow STARTER BOX GETS STUCK!!!!!!
Every time i try to start my buggy on the starter box it feels like the motors get hung up on the brushes or something because it just jams up and i have to physically rotate it to free it back up. The gell cell is fully charged so it's not the battery. I have had it stored for a little bit but i had put after run oil in it before i stored it. I have checked both motors in the box and they both work seperately so i am stumped. Can anyone help me out as i would like to race it in two days time but only if it starts Any help would be great. Thanks
freestyles is offline   Reply With Quote
Old 07-06-2008, 04:17 PM   #2
Do the motors in your starter box get stuck or does your nitro motor get stuck? When you say you put after run oil in it and stored it, what are you referring to? Just based on what I can interpret it sounds as if your nitro motor still has a lot of pinch and you need to heat the crankcase up with a hairdryer or heat gun before running so as to loosen the piston/sleeve up.
843rcguy is offline   Reply With Quote
Old 07-06-2008, 04:36 PM   #3
badassrevo's Avatar
I had the same problem and found one of the bearing in the wheel frozen.
Doug Lightcap
ARCS Hobbies / Paint Monster Airbrushing / BFast / Tonys Screws
badassrevo is offline   Reply With Quote
Old 07-06-2008, 10:48 PM   #4
freestyles's Avatar
Arrow
I pulled the wheel out and checked the bearings as that was one of my initial thoughts but when i did they were fine. I just went and bought a pull start mechanism for the sts .30 that i have but i would prefer to run the backing plate. Anymore help would be great
Old 07-13-2008, 08:44 AM   #5
kevinmajor's Avatar
I would check all electrical connectors. Solder the connections on the motors, batteries, and main switch.
Check the pressure switch for current flow. Maybe clean the contacts with fine sandpaper and elec contact cleaner.
Check to make sure the drive belt isn't binding.
Check each motor for metal things stuck to the magnets inside the motor can. I found a staple that binded up an electric motor. The clearance between the comm and arm in the motor is very tight, and it might be hit and miss (sometimes it binds, sometimes it doesn't.)
Those are the things I can think of. Good luck and tell us how it goes.
kevinmajor is offline   Reply With Quote
Old 07-13-2008, 11:43 AM   #6
throw your starter box away.
stick with the pullstart you cant go wrong with a PS.
new to rc cars is offline   Reply With Quote
Old 07-13-2008, 11:48 AM   #7
Suspended
I don't know which is worse - you not knowing enough to tighten a glowplug, or advising to use a pullstart.
rocket-mtrsprts is offline   Reply With Quote
Old 07-13-2008, 11:49 AM   #8
I said in my other thread: I was in a hurry and forgot.
dont act smart, it doesnt suit you.
Old 07-13-2008, 01:41 PM   #9
Suspended
DITTO
Help! Stuck Carb! hrnts69 Nitro Off-Road 10 12-09-2008 07:10 AM
OS TZ .12 Stuck at TDC theBUZZ Nitro On-Road 44 12-01-2006 05:47 PM
Please help with stuck airbrush dct147 Painting, Designs, Graphics and Photography 11 05-03-2006 01:40 PM
Okay, Now I'm Stuck finny Australian Racing 8 04-18-2004 06:37 PM
OS .12 tr came stuck in TDC AE Racer Nitro On-Road 19 08-15-2003 10:22 PM
