Old 07-05-2008, 07:51 PM   #1
Default HOBAO HYPER 8.5 PRO VS TEAM LOSI
hi to all rc racers out there,
is there a possibility that hyper 8.5 pro is setup till its on par with team losi 8 ?
does you guy hav the stock setting sheet for hyper 8.5 pro ? cheers
novaa is offline   Reply With Quote
Old 07-05-2008, 08:47 PM   #2
Trader Rating: 29 (94%+)
here is all I can find as far as set up goes for your 8.5
Hyper 8 set up:
BBF110-7000-4000
Front shocks:
4 x 1.4mm, 60wt
One in from outside JQ tower. Outside on hyper 7 arm, with wide JQ arm holder.
Front link, upper hole on tower, outside on hub
22 degree caster
Front kick up, Nr 2 with hole up
+ with hole down
2.5mm swaybar
Ackerman in middle hole
27 rideheight
9mm upper turnbuckle visible
19.5mm steering link turnbuckle visible
Rear shocks:
4 x 1.5mm, 55wt
Mugen Grey springs, medium lenght
outer on JQ tower
Inner on arm
Rear link in inner upper on tower (need to grind gearbox for clearance) Upper outer on hub.
Arm in lower hole on hub
Hub in the middle
3 antisquat
2.5 toe in
2.8 swaybar
29 rideheight
rear about 21mm visible on turnbuckle, i really cant say cause i dont know.
i was thinking 5/7/1 in the diffs, driveshafts level
kcpipeliner is offline   Reply With Quote
Old 07-05-2008, 09:11 PM   #3
hey thanks alot for sharing thise stock setup.
its for my fren actuLLY. HE just simply duno anything bout this buggy. i did read the manual and setup sheel and it doesnt say much bout shock weight and the diff oil. thanks again cheers
Hyper 8 set up:
BBF110-7000-4000
Front shocks:
4 x 1.4mm, 60wt
22 degree caster
+ with hole down
2.5mm swaybar
27 rideheight
Rear shocks:
4 x 1.5mm, 55wt
outer on JQ tower
Inner on arm
Hub in the middle
3 antisquat
2.5 toe in
2.8 swaybar
29 rideheight
Old 06-26-2010, 08:27 AM   #4
ferhobby's Avatar
Amigo forward and back height of the chassis?
What oil use in the diferentials (r,c,f)??
i habe spider diff.
thanks
ferhobby is offline   Reply With Quote
Old 06-26-2010, 08:38 AM   #5
easyryder's Avatar
This is what you need Read on, the Russ Jones set-up tips is good reading. As far as the Hyper 8.5 to compete with losi 8, it sure can,
Robert Battlie made the Worlds A main with that car a couple years ago, tons of Losi 8s at that event
XRAY XB9. Rubber tires with foam inside and super glue to keep them on. Cheap, but fast radio, high dollar servos, savox, mostly.
Cheap .21 engine. Modern starter box, finally!
easyryder is offline   Reply With Quote
Old 06-29-2010, 09:27 PM   #6
ferhobby's Avatar
Default This is what you need Read on, the Russ Jones set-up tips is good reading. As far as
amigo do you have teh link? ( the Russ Jones set-up tips ) please
Old 06-30-2010, 07:21 AM   #7
easyryder's Avatar
oops, here you go
http://www.ofna.com/forum/viewforum....33522b53d5b284
Old 06-30-2010, 08:44 AM   #8
ferhobby's Avatar
thanks amigo just that in need
what servo you use in the stering??
Old 06-30-2010, 08:48 AM   #9
easyryder's Avatar
JR 9100 s Are the best imo, cost is high, but super fast, durable and great 3 yr warrenty
Old 06-30-2010, 08:56 AM   #10
I would recommend Hitec servos... 105$ for 7955TG its a great servo can't say anything about their customer servo as I have never had to deal with it. Still using the same 5955TG from years ago.
Team Losi 8ight 2.0
Team Losi Nitrotec w/ 2013
riverviewrc is offline   Reply With Quote
Hobao Hyper .12 vc05hdt Onroad Nitro Engine Zone 43 06-08-2009 06:18 AM
Hobao Hyper 8 Pro FS revt1 R/C Items: For Sale/Trade 3 04-24-2007 07:26 AM
HoBao Hyper 7 dr_catman Singapore R/C Racers 39 03-15-2007 08:00 PM
Hobao Hyper GP4 bboytab Nitro On-Road 4 11-14-2004 09:35 PM
