Old 07-03-2008, 07:07 PM   #1
Trader Rating: 35 (100%+)
Default running 30% tq fuel in a c6bbT
i am switching from 20% byrons to 30% tq fuel in my c6 bbt....question for ya is do i need to add a rb .1mm shim for 30%. thanks guys!!!
losiracer22 is offline   Reply With Quote
Old 07-03-2008, 07:45 PM   #2
Trader Rating: 20 (100%+)
yes i did
xxx123 is offline   Reply With Quote
Old 07-03-2008, 11:08 PM   #3
I would and do on all my RBs running 30%. If you don't add a shim you will want to run a cold plug.
Orange RC8 with a bunch of crap in it.
largeorangefont is offline   Reply With Quote
Old 07-04-2008, 09:30 AM   #4
PowerHouse's Avatar
Trader Rating: 66 (100%+)
Most engines come in the box setup for 25% and they recommend that. These numbers are conservative and if you are a half way decent tuner you won't have to touch it. In fact I usually take a .1 shim out of most of my personal engines when I run 30% because i get more torque but the tune has to be spot on if you do that. Most people add shims as a safety measure but you can also do it if you want to calm down the low end. Less compression ratio equates to less initial torque but may add a few more rpms on top due to the fact the motor doesn't have to fight as hard to compress the mixture. So basically its up to you if you want to add the shim or not but it is not required.
PowerHouse is offline   Reply With Quote
Old 07-04-2008, 10:28 AM   #5
Lowering the compression also increases mileage.
RB C6BBT L2G or OS Speed 21. josh_c Nitro Off-Road 44 09-10-2008 07:47 AM
RB C6BBT, what other plugs can I use? savagebeing Nitro Off-Road 16 09-08-2008 01:26 PM
20% byrons gen 2 in a c6bbT losiracer22 Nitro Off-Road 15 06-28-2008 10:36 AM
OS V-Spec vs RB C6BBT Kiowa Nitro Off-Road 31 02-29-2008 07:55 AM
Rocket Science fuel, who's running it? K.Copeland Nitro Off-Road 17 09-02-2007 09:05 AM
