Old 07-03-2008, 10:33 PM   #16
rallyebmx's Avatar
Trader Rating: 21 (100%+)
Yes, keep bumpin it with the glow igniter on until its OUT. I run a p7 as well. Just switched to the Gen 2(its just made me run richer) and OFNA diff fluid
rallyebmx is offline   Reply With Quote
Old 07-03-2008, 10:53 PM   #17
Originally Posted by Nitro syco View Post
I completely dissasemble my motors almost every run so I am going to guess that this was not a maintenance issue, and for me I had rust after 1 gallon, so I cleaned it up as best as possible but a gallon or two later it came back to haunt me and the rust took my rear bearing. Maybe I dont clean my motors well enough when they are apart but it seems like its more that just a coincidence that it has only happened with nitrotane, and it also happened to some fellow racers.
It depends on the fuel. I can assure you rust is not forming while engine is running. I have seen engines rust overnight when fuel is left in them. This seems to be a function of the fuel.
Blue Thunder does this and it sounds like Nitrotane does it as well. Trinity fuel used to do it as well. O'Donnell does not seem to do this. I don't think the new Byron's stuff does it either.
You just want to make sure you burn up all the alcohol in the fuel system and engine so it does not create moisture in the engine and start to rust it.
Orange RC8 with a bunch of crap in it.
largeorangefont is offline   Reply With Quote
Old 07-03-2008, 11:00 PM   #18
Originally Posted by wstuart View Post
Yeah I took the backplate off my p7r and I noticed some corrosion on the crank. - is that bad? Its a pretty new motor and I put obicco afterun in after every race day. should I burn all the fuel out before I put in the after run oil?
Yes burn all the fuel out. This will do more to prevent rust than using after run oil. A little rust on the crank is not a big deal. If you are worried about it you can pull the crank out and clean it with a very fine emory cloth soaked with after run oil.
Don't use the emory cloth on the crank journals.
Old 07-04-2008, 08:47 PM   #19
Will: run Gen2 Byrons or Nitrotane. Diff oil run 5,000 front, middle, and rear.
Mitch
Mitch P. is offline   Reply With Quote
Old 07-05-2008, 12:50 PM   #20
GH Racing's Avatar
Nitrotane and Mugen diff oil
GH Racing by Golden Horizons. Buy Direct At: WWW.GHHOBBY.COM
FOLLOW US ON TWITTER NOW: twitter.com/GH_Racing
High Quality Machined Aluminum Parts and Accessories. Vancouver, Canada.
GH Racing is offline   Reply With Quote
Old 07-05-2008, 03:04 PM   #21
Trader Rating: 26 (100%+)
Send a message via AIM to cheesecake
i run any diff oil but mugen...........mugen oil has a tendency to disappear
cheesecake is offline   Reply With Quote
Old 07-06-2008, 10:36 AM   #22
crazy4wdracer's Avatar
Trader Rating: 25 (100%+)
Send a message via AIM to crazy4wdracer
I like trinity fuel a little more than o'donnell. I can't speak for byrons because none of my lhs's carry it and I have never used it. I run 20% fuel though, not 30%. I run associated shock oil and mugen diff oil.
crazy4wdracer is offline   Reply With Quote
Old 07-06-2008, 10:53 AM   #23
Trader Rating: 36 (100%+)
I'm partial to Rocket Science fuel with Byrons a close second when the former isn't available.
rstnboy is offline   Reply With Quote
Old 07-06-2008, 01:18 PM   #24
Oasis's Avatar
I completely disassemble my motors almost every run .
....that seems like a lot of work..if i never crashed or always had motor problems i would think about doing this..but i already have a job..never wanted to turn my hobby into one..
On the fuel..I guess asking what the best fuel is, is sorta like asking what the best buggy or truggy is..I have always run the O'donnell's..Recently I switched to Byron's..I'm switching back to O'donnell's..On some of the other fuels.. i basically run what i can get at my local hobby shop and the choice I have is Traxxas, Byrons and O'donnell's..
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 07-06-2008, 03:01 PM   #25
tony montana's Avatar
Trader Rating: 65 (100%+)
I never take my engines apart anymore unless they are used when I buy them. It seems to me the more you take the engine apart the more tuning issues I had. So far on my rb s7 l2g I havent had a flame out with it yet since being race tuned. I havent took anything apart on it. Also Im running byrons gen 2 fuel also. I have noticed since running byrons I have had to richen my engines up quite a bit, since running tq fuel before. I also see no need to run anything higher than 25%
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
Old 07-06-2008, 03:10 PM   #26
Oasis's Avatar
Agreed 100%..the other thing i have noticed is the guys that have run their motors to lean on Byron's (once is all it took) their motors were gone..i have seen others run to lean on different fuels and not destroy their motors..I tend to run a bit on the "fat" side and i did notice that i had to richen my engines up quite a bit also..
what do you reccomend ryan type R Nitro On-Road 21 12-22-2010 06:32 AM
What radio upgrade would you reccomend and why? Furadi Nitro Off-Road 44 08-20-2008 01:06 AM
reccomend a good charger.. raidvs Australian Racing 19 01-02-2007 12:44 AM
What equalizer do you reccomend? AE Racer Electric On-Road 42 09-08-2004 09:43 PM
Which truck do you guys reccomend? Skoob Monster Trucks 2 04-06-2004 02:44 PM
