Old 07-03-2008, 08:19 AM   #1
will g's Avatar
Trader Rating: 132 (100%+)
Send a message via MSN to will g
Default Starter box problems
Hi all got little question/problem I got a mugen off road starter box from a friend and it has the 2 stick packs ( 1600 ) and it will not turn over my motors is it possible that the motors are weak? i pulled the belts off and both motors turn in the starter box, but dont have enough to turn it over. i have to shim the starter box motor up but i think its too close to the flywheel now. if its too close it dont have to to turn before it hits poss? if anyone has anything on this please let me know thnx will g
Will Garza
TLR 22SCT Tekin RS Pro-Fantom 9.5/TLR 5ive-T
will g is offline   Reply With Quote
Old 07-03-2008, 09:28 AM   #2
carlosm's Avatar
Trader Rating: 17 (100%+)
I'm using the mugen box for my buggy, I bought it used. The guy I bought it from had it wired to hook up to an external gel cell battery. All I did was bought a lipo starter box battery and mount it inside the box with industrial strength velcro. The box has plenty of power to start both my Werks & Ninja Engines. P.S. make sure you upgrad the plug to a Deans plug.
carlosm is offline   Reply With Quote
Old 07-03-2008, 09:52 AM   #3
will g's Avatar
the plugs are deans and i think im doing something wrong just not sure. need some opinions thnx will g
Will Garza
Old 07-03-2008, 01:47 PM   #4
RC Dad's Avatar
Trader Rating: 26 (100%+)
Send a message via MSN to RC Dad
I'd probably try new batteries. Those 1600 stick packs might be old Nicds. If your motor is really fresh you might try heating it with a hair dryer or heat gun to loosen it up a bit before starting it.
Also try to let the wheel spin up to speed on the starter box before hitting the flywheel. If it's shimmed up too high the flywheel might make contact before it starts spinning as you suggested. Pick up the front end of the buggy while pushing the rear down to start the motors spinning, then drop it to let the flywheel contact.
GV2 Pro, XXX4G+, Blitz SCT, CRC GenXL
RC Dad is offline   Reply With Quote
Problems with new starter asar5205 Malaysian R/C Racers 16 12-10-2006 01:20 AM
Help needed: starter box problems! Illusion-Lighti Nitro On-Road 4 07-19-2004 12:28 AM
starter box problems TC3 BUDRACER1 Rookie Zone 7 09-09-2003 01:15 PM
new TC3 starter box problems BUDRACER1 Nitro On-Road 4 09-05-2003 02:07 PM
Starter Box problems :( ttektek Nitro On-Road 3 03-16-2003 05:31 PM
