Old 07-01-2008, 02:42 PM   #1
Trader Rating: 16 (100%+)
Default 1/8 Buggy compared to truggy?
I am currently running an 8ight buggy. Overall, I enjoy running the buggy, however I was considering switching to a truggy. I don't have a real good reason, other than trying something different.
For racers who have run both could you please comment on the following:
Which one (buggy or truggy) is easier to drive?
Which one is more durable?
Which class is stronger overall? I suppose this varies based on the track.
Which one is more fun overall to own?
Anything else that I did not list, but I should consider.
I prefer to stick with Losi, but I am not a die-hard fan. For a racer with average skill level, is the 8ight-T a good truggy? The initial lower cost and part availability is appealing for the 8ight-T.
brianr34 is offline   Reply With Quote
Old 07-01-2008, 02:52 PM   #2
badassrevo's Avatar
The truggy is easier to drive
The buggy is more durable
the buggy class is stronger
They are equally fun to own
The 8T would be a great truggy just replace the rear outer hinge pins with the M2c 5/32 pins and you will be set.
Doug Lightcap
ARCS Hobbies / Paint Monster Airbrushing / BFast / Tonys Screws
badassrevo is offline   Reply With Quote
Old 07-01-2008, 02:52 PM   #3
Truggy is easier to drive and it's more durable. Buggy is proabaly a little bit bigger class than truggy cause it's more competitive, but it also depends what the racers at your local track race the most. Everyone I know says the truggy is the most fun. I dont have a truggy or a buggy but I have driven both and I liked the buggy as much as the truggy. The losi is good, but im going to try the Kyosho ST-RR truggy when I get enough money. Hope this helps.
Mitch
Mitch P. is offline   Reply With Quote
Old 07-01-2008, 02:58 PM   #4
K_B
K_B's Avatar
Trader Rating: 69 (100%+)
I started with an 8ight buggy last season and bought an 8ight truggy for this season. WOW! Totally different animals. The buggy takes WAY more finesse to drive. You can drive the truggy much more aggressive than the buggy and get away with it. The truggy is much more forgiving handling-wise. The jury is still out on durability but so far, it's holding up quite well.
I'm still partial to the buggy because of the handling characteristics, but on a REALLY rough track, I enjoy the truggy more because it just handles the rough stuff so much better. On a decent track, the buggy is much more entertaining to me.
K_B is offline   Reply With Quote
Old 07-01-2008, 02:59 PM   #5
The class size depends a lot on where you are, at the three closest tracks to me truggy is a larger class but at other tracks I have been to buggy is larger, just depends on where you drive.
Nitro syco is offline   Reply With Quote
Old 07-01-2008, 03:00 PM   #6
RETRO RC's Avatar
hey brian
#1 truggy -it's a lot more forgiving
#2 buggy -the truggy is very strong I've never broken anything on the 8t but wear on parts is higher due to the increased weight
#3 as you said this depends on the local environment
#4 if you just want to have fun racing the truggy is more forgiving and you'll probably enjoy it more
the only other thing to cosider is running costs.
truggy tanks are bigger 150cc and last about the same time as a buggy, tires are more expensive but some last longer than buggy tires, clutches wear faster due to the extra weight.
If you go for the 8T definately get the rear bearing inserts and keep an eye on the centre front driveshalft and the diff casings on the centre and rear diffs
Hope this helps
Adrian
Agama A8 EVO 11 spec/ Argus A52 .21
Agama A8T / Argus A52 .23
offroaders get more jumps and like it rougher!
RETRO RC is offline   Reply With Quote
Old 07-01-2008, 03:23 PM   #7
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Originally Posted by RETRO RC View Post
hey brian
Hope this helps
Adrian
Also the ring and pinions on the 8ight-T are a problem area... keep an eye on them. If you destroy a pinion gear... you should replace the ring, pinion, and plastic diff housing (not the case, although those wear also... get the heavy duty diff cases with the metal inserts) meaning the part that the diff sits inside of and the shock tower bolts to. And absolutely, positively get the aluminum bearing holders for the rear diff.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 07-01-2008, 03:35 PM   #8
Thanks for all of the feedback so far about the truggy.
Could someone explain the different offsets for truggy tires? I have heard the term, but I do not understand what it means. How many offsets are there for a truggy and what is reason for the offsets?
Also, would a 8ight-T with a stock set-up, only be able to run certain offsets.
I mainly would be racing on an indoor track, so any help on the offsets would be appreciated.
WTT Mugen Truggy for BL Buggy or Truggy trdsupra88 R/C Items: Wanted to Buy 2 08-12-2008 10:24 AM
thunder tiger st-1 truggy trade for ocm truggy are buggy DPowers R/C Items: For Sale/Trade 3 04-02-2008 04:29 AM
looking to trade a thunder tiger st-1 truggy for an ocm truggy are buggy. DPowers R/C Items: Wanted to Buy 0 03-31-2008 04:49 PM
HPC Monthly Off-Road Race (1:8 Buggy, Truggy & EP Buggy) - September HPC II Malaysian R/C Racers 120 09-19-2006 11:57 AM
Xxx-s Slow Compared To Tc3 losi211 Rookie Zone 20 03-11-2005 05:41 PM
