Old 07-01-2008, 04:13 AM   #1
Default Killing glow plugs somehow
Hey all
Helping tune and seal up a Team Infinity Samurai 521 that has been modded a bit..
It wasn't running that great and i tunned it up a bit and it holding temp around 110c now and going pretty good. I had to wind out the MSN a very small amount as the HSN was only just kicking in at high rpm..
It is killing glow plugs very often though. using standard OS #8's and we have tried cooler plugs also with no luck.
I cant think of anything out of the normal except we are using a old RTR type ehaust which is just fully open and loud! we have a jp3 on the way...
Is there anything i should be looking at specifically?
The plugs appear slight carboned up, the last spring is out of shape a little bit and they will onlu glow the first couple rings...
thankyou all please just list the things you would be checking..
ps. this engine has never been in a good state. it has only about 3-4l through it and has been hard to tune since new. well it tunes fine but then runs hot or if tuned to run at a normal temp it doesnt quite run great and the plugs go real quick. in the 3-4L i think we have used near 9 plugs
in that time my vspec is still on its first!
thanks
MBX5R - OS VSpec - Futaba 3PKs - Hitec 5955's- LRP Lipo - Proline
MBX5T - RB C6 L2G - Futaba 3PKs - Hitec 7955's - LRP Lipo - Proline
pracy is offline   Reply With Quote
Old 07-01-2008, 05:45 AM   #2
Merciless's Avatar
Send a message via ICQ to Merciless
Your sure the LSN isn't set too lean ?? I find thats the normal cause if I start eating plugs !
Just a thought
Rod
Merciless is offline   Reply With Quote
Old 07-01-2008, 06:21 AM   #3
i am fairly sure its not. I give it a good run then count a couple seconds and then hit it and it has a good amount of smoke coming out. I have only just gone past the point where it is bogging off the line..
i was just about tot ry the pinch test when the last glow plug died
Old 07-01-2008, 06:40 AM   #4
GSPOT's Avatar
Trader Rating: 62 (100%+)
Send a message via AIM to GSPOT
CON ROD OK?
VTA member #126
GSPOT is offline   Reply With Quote
Old 07-01-2008, 08:48 AM   #5
RC Dad's Avatar
Trader Rating: 26 (100%+)
Send a message via MSN to RC Dad
If the plug is carboned up you may still be running too rich. Make sure you have fresh fuel.
You state that the motor is new, but how old is the car it was put in? Check for air bubbles in the fuel line, pinholes happen and can really mess up a tune. Or if it is a season or two old, just replace the line. Quick $5 fix
Also it helps to replace the o-rings on the high and low needles as they get hard and leaky with age and heat. Quick $4 fix
GV2 Pro, XXX4G+, Blitz SCT, CRC GenXL
RC Dad is offline   Reply With Quote
Old 07-01-2008, 09:24 AM   #6
slow coach's Avatar
im quite sure my mate had one of those motors a while back he could never tune it properly and it would just not run right no matter what he tried i think he gave up in the end, sorry not the answer you want
Kyosho MP9TKI2 soon to be TKI3, Novarossi, SMD, GM Racing, www.grccc.org
a great wife and lovely kids
what more can you ask for
a win on the lottery :D
slow coach is offline   Reply With Quote
Old 07-01-2008, 05:49 PM   #7
thanks for you answers guys. the buggy is a new 808 and the conrod does have a fair amount of slop in it considering the engine is fairly new i was surprise at the amount of slop!
I am going to wack a sapre vspec carb on it and also try a os speed mag head and turbo button see if that helps...
lol its a black block too so its gunna look like a os speed just not run like one..
though this engine is quite fast and keeps with my vspec just doesnt have the punch off the line..
Old 07-01-2008, 06:25 PM   #8
jrwoodchuck's Avatar
One way to tell is buy looking at the wire in the plug compared to a new one. If it looks like its pulled out, you're too lean. If its pounded up in, you're too rich. This can give you a starting point. But if all else fails go richer, plus try the factory settings. They tend to be on the safe side.
Doug
TLR 22/M-11
“Looks like I picked the wrong week to quit sniffing glue.”
jrwoodchuck is offline   Reply With Quote
Old 07-01-2008, 06:45 PM   #9
Crim3Wav3's Avatar
i tend to agree with the "rod theory"....i was blowing plugs every other run for 2 weeks with a loose v-spec rod. Didn't take much.
Crim3Wav3 is offline   Reply With Quote
Old 07-01-2008, 06:51 PM   #10
wingracer's Avatar
Trader Rating: 23 (100%+)
Had the same problem this weekend. The cause was the con rod bushings.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 07-02-2008, 01:13 AM   #11
thanks guys
its not worth it to change the conrod on the motor as its only a cheap motor til he gets a new better motor.
whats an easy fix, how bout adding a shim or maybe trying two glow plug washers?
i am guess the slop in the rod is allowing the rod ti rise higher causing the problem?
cheers
Old 07-02-2008, 05:41 PM   #12
Trader Rating: 36 (100%+)
I have a Top motor I bought used that blew glow plugs frequently. Once I took it apart for a look-see, I found out it didn't have enough shims. Once I corrected that, all is well.
rstnboy is offline   Reply With Quote
Glow Plugs ? Fuzzchop Nitro Off-Road 1 04-13-2008 04:42 PM
Glow Plugs stiffler297 Nitro Off-Road 4 08-20-2007 11:02 AM
Nitro accessories needed: Glow Plugs, Glow Ignitor, Temp Gun Cain R/C Items: Wanted to Buy 8 07-05-2006 05:22 PM
Glow plugs bigmo_rc10 R/C Items: Wanted to Buy 0 10-11-2005 08:31 PM
Will a standard glow ignitor work on a turbo glow plugs? Ducati998 Nitro On-Road 3 01-19-2003 11:54 PM
