Old 06-29-2008, 05:29 PM   #1
Trader Rating: 35 (100%+)
Default tunning help, new c6
hey guys, just got my c6 broke in and it is a sweet motor......i started race tuning it and it is running around 242.......and good smoke so i wanted to try the pinch test and i made a pass wide open and pulled it in and pinched the fuel line right by the inlet on the carb.........the rpms increased and stalled after 3-4 secs, my concern is, that is was more of a machine gun sounding rev up like it was missing. is this ok???
losiracer22 is offline   Reply With Quote
Old 06-29-2008, 06:47 PM   #2
It's a bit too lean on the bottom.
Orange RC8 with a bunch of crap in it.
largeorangefont is offline   Reply With Quote
Old 06-29-2008, 07:00 PM   #3
lowey79's Avatar
i thought with the pinch test that it would stall imediately if the tune was lean? If it's reving up considerably for 3-4 sec then it will still be a bit rich....
The revs should increase slightly for no more than 2 sec and you on good tune...
These days, i tune to the idle. Once the idle gap is set, adjust the mixture accordingly. If it idles high, it's slighty lean. If it idles low, it's slightly rich....
This will only work when you get the idle gap right, as you can get a false lean if the gap is too big.....
lowey79 is offline   Reply With Quote
Old 06-29-2008, 07:05 PM   #4
You want a slow steady increase in rpm, not the machine gun sound. Though the sound could be because it is not fully broken in yet. It will take around a gallon before the engine fully loosens up.
RBs like the bottom a bit on the rich side anyway.
Old 06-30-2008, 12:01 AM   #5
thecman26's Avatar
Trader Rating: 98 (100%+)
Thumbs up
Wheres Mike Elam when ya need him?
He is the guy to ask on this one..
He is the C6 tuning god!
Got mine running like a MONSTER with a little of his magic!
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 06-30-2008, 09:22 AM   #6
correct me if I am wrong but I tuned my motor on the road.....so on the track it may be slightly different.....probably a little rich? also the low speed needle is 5.5 turns out.....stock settings are 5. my high end is in between 3 and 3.5. thanks for everyones help!!
Old 06-30-2008, 11:24 AM   #7
GHETTOTEACHER's Avatar
Interesting. My C6 runs at 212 during a race. Most of my friends that have C6's; theirs run stong and hard at 196-220. That is at 90 degrees outside temp. Sounds like you are a bit lean on the bottom.
Herolin <---Traded my Airtronics for an Ipad and Laptop...
Soon to be GHETTOPRINCIPAL..
GHETTOTEACHER is offline   Reply With Quote
Old 06-30-2008, 11:32 AM   #8
Yes the tune will be different in the dirt, but you will need to retune it at around a gallon when it fully loosens up. I would run it around 200 until that happens.
Old 06-30-2008, 02:00 PM   #9
ok guys thanks....I just didn't think that I would have to richen the bottom that much from the factory. I am also running byrons 20%. I will richen the bottom a couple ours and see if I can get it around 210 with the body on. and see how it does.
Old 06-30-2008, 06:50 PM   #10
forgot to mention......i am running a werks fironi coooling head, think that is better or worse than the stock c6 head
Old 07-01-2008, 05:33 AM   #11
I was wondering what my idle gap should be set at how far from closed? I am going to set it and tune the low end for idle.
Old 07-01-2008, 09:05 AM   #12
The low end on my S7 is set so that when you open the carb all the way, the tip of LSN is exactly half way across the carb throat.
So if you are running the OEM 7mm restrictor, you should have about a 3.5mm gap between the carb throat and the tip of the LSN at WOT.
That will get you in the ballpark. A C6 will run a similar setting.
Tunning Bigwattsus Rookie Zone 1 06-19-2006 01:59 PM
tunning help kerry Electric Off-Road 2 03-25-2006 12:53 PM
tunning lachlan90 Australian Racing 3 01-13-2004 10:37 PM
tunning help lachlan90 Onroad Nitro Engine Zone 1 01-13-2004 09:14 PM
tunning help lachlan90 Nitro On-Road 1 01-13-2004 07:04 PM
