Old 06-28-2008, 09:04 PM   #1
hrnts69's Avatar
Default New Carbs? Have a stuck one!
Hello, after running my first Off-Road Race with a Vintage OFNA Buggy, its now time to finish my Sportwerks Turmoil Pro Buggy. Ive got what i beleive is a Fantom Nitro Engine. The head is Red, and on the block its has F with 3.5cc underneath it. It has somewhat good compression, but its the only engine i have.
Now for the problem. Its a Slide Carb, but its stuck closed! Ive tried everything from DeepCreep to heating it up. and it still wont come lose. So ive decided on a new Carb. So whats a good Carb to consider? Or do you guys have any more ideas on fixing my carb?
Thanks in advance, Blake
Hobby Sport Media
www.hobbysportmedia.com
facebook.com/hobbysportmedia
hrnts69 is offline   Reply With Quote
Old 06-28-2008, 09:11 PM   #2
Integra's Avatar
is a new motor all together out of the budget ?
Old 06-28-2008, 09:46 PM   #3
Is the idle screw all the way open by chance?
Furadi is offline   Reply With Quote
Old 06-28-2008, 11:36 PM   #4
If you left the engine lying around for a long time. My guess is that your engine is all gummed up inside causing your carb to get stuck. If that happend to me I would remove all the needles and take the whole carb assembly apart. If im not mistaken you can unscrew the idle needle all the way out and that would free the slide. You could try prying it out then.
Genius is offline   Reply With Quote
Old 06-29-2008, 06:46 AM   #5
hrnts69's Avatar
I bought the engine at a Swap Meet for $5. Yes, a new .21 engine is out of the budget unless its under $110. I backed out all the screws, and nothing happen. Will prying on the slide inside the carb hurt it? Might have to try that??
The engine turns over, but not alot of compression. Is there a rebuild kit for these engines?
Hobby Sport Media
Old 06-29-2008, 05:57 PM   #6
Integra's Avatar
a rebuild is normally 100-200 pending on what kind of motor it is and how far u want to take it....piston and sleeve....rod...bearings.......so in reality....i would get Saving and look for a new .21 of some sort.....Gotech's are cheep and reliable. check em out.
Old 06-29-2008, 06:10 PM   #7
Pauly6401's Avatar
Trader Rating: 41 (100%+)
Email Brian - breedy2@columbus.rr.com - he is a Go Tech dealer and might be able to get you a new .21 and fit your budget at the same time. That way you will have a great engine and you can take your time and mess with the swap meet one to try and turn it into a backup.
Losi XXX-T CR * Traxxas Revo Tekno Brushless Conversion * Losi 8ight 2.0 * Losi 8ight-E 2.0 * Corally RDX * HPI Blitz * Tamiya F104 V2 Pro * Associated TC 6.2
Pauly6401 is offline   Reply With Quote
Old 06-29-2008, 08:22 PM   #8
asw7576's Avatar
Drop couple of oil into carburator opening, and slides the throthle slider couple of times. Do this again for every maintenance time.
just a ? on carbs sioux101 Electric Off-Road 2 04-04-2006 06:36 AM
3 needle carbs themoose Onroad Nitro Engine Zone 3 05-07-2005 08:52 AM
Torque Carbs. picco007 R/C Items: For Sale/Trade 2 10-08-2004 07:02 PM
learning my carbs hareball Rookie Zone 8 09-12-2004 03:42 AM
Carbs vala Nitro On-Road 2 06-25-2004 01:51 PM
