Old 06-27-2008, 02:41 PM   #1
ALG
Default Rims diameter?
Can some one help us and give us some knowledge on the different size of rim diameter.
I have OFNA 86057 TrueLites rims with 82mm diam and comparing with the JC rims Rulux 3303Y, JC rims are smaller. what is the effect? it is better or worse? when would you recomend a big rim or a small rim?
Thanks for your help and have fun!!
ALG is offline   Reply With Quote
Old 06-27-2008, 03:02 PM   #2
K_B
K_B's Avatar
Trader Rating: 69 (100%+)
Weird... according to Tower, the OFNA wheels are 4mm shorter than the JCs. If it were me, I'd go for the bigger rim. That way, the tire will fit snugger to the rim and easier to glue.
K_B is offline   Reply With Quote
Old 06-28-2008, 06:26 AM   #3
Trader Rating: 18 (100%+)
Send a message via Yahoo to infanterene
Smaller rim can give you a rounder profile. A rounder profile will catch less ruts and carry more corner speed. It will also usually have less forward traction and the center will wear faster.
RC America - Team X-Ray - Maxys Fuel
infanterene is offline   Reply With Quote
Old 06-28-2008, 11:49 AM   #4
ALG
I have both rims and the diameter are 82mm for the Pfna and 78mm for the JC.
The above measurments are on the rim.
I was thinking, bigger rim = less tire profile, less flex, better on blue groove and good tracks. smaller diameter = more profile, more flex better on bumpy and ruts track.
my 2 cents.
Have fun
Old 06-29-2008, 02:15 AM   #5
COBRARACING's Avatar
my 2 cents.
Have fun
All this talk about bigger rims etc etc is all balony its all got to do with the strength and the quality of the tyre wall not the rim being 82mm or 83 mm the bigger the better .
if the tyres are manufatured with accuracy and quality in mind to have a strong tyre wall then the rim can be 78mm or 80mm they dont have to be any bigger.If the tyre is total crap quality it doesnt matter if the rim is 90mm it wont make a difference with power to ground effect.
You only need a bigger rim diameter if you use crappy tyres with thin walls this way compressing the tyre to a smaller profile creating some strength in the wall of the tyre not to cause flex.
You can get the power to the ground with a smaller 80mm rim as long as the tyre has a excellent tyre wall manufacture strong in other words which wont flex as much as the others.
and all the rest is history take care friends
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
tire cut diameter racer43 Nitro On-Road 11 11-15-2006 05:05 AM
Motor diameter ???? teammidget lilB Electric On-Road 2 09-11-2006 02:57 PM
tire diameter andy_b22 Rookie Zone 2 03-12-2006 08:26 PM
Diameter of Sorex 28. Snikkari Electric On-Road 1 10-25-2005 10:01 AM
arm wire diameter h22ah Electric On-Road 4 06-10-2004 08:01 AM
