Old 06-25-2008, 05:00 PM   #1
Trader Rating: 35 (100%+)
Default o.s vpec running 20% need to remove shims?
hey guys i am going to start running my vspec on 20%, it is a eb modded....i didn't know if i need to take a shim out. thanks for your help!
losiracer22 is offline   Reply With Quote
Old 06-25-2008, 05:40 PM   #2
wingracer's Avatar
Trader Rating: 23 (100%+)
You do not have to take a shim out. You may be able to take a shim out to try and find that little extra bit of horsepower or leave it in to be safe and get better mileage. If you do decide to pull a shim, run one good hard tank with a new plug and check it after the run. If it shows any signs of distortion put the shim back in.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is online now   Reply With Quote
Old 06-25-2008, 07:04 PM   #3
thanks wing for your post in both of my threads!!!
Pipe for OS Vpec? Reznor88 Nitro Off-Road 16 04-07-2008 10:26 PM
Having problems starting my O.S Vpec in my Losi 8ight Please help NJA82 Nitro Off-Road 12 09-20-2007 04:18 AM
Will I need head shims on OS V-SPEC if running 30% Nitro patrick21x Nitro Off-Road 12 07-01-2007 12:42 AM
can you remove a piston with out remove the sleeve? downunder23 Rookie Zone 3 08-17-2006 06:00 PM
Do I need extra Shims for a Mr-12 when running 30%? Dust Nitro On-Road 8 11-18-2003 10:05 AM
