Old 06-24-2008, 02:13 PM   #1
DPowers's Avatar
Trader Rating: 79 (100%+)
Default fuel line routing question
does running if your fuel line beside your pipe are the head of the motor couse any kind of problems.
DPowers is offline   Reply With Quote
Old 06-24-2008, 02:23 PM   #2
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
yes! You want to keep your fuel line away from your pipe and head. Heating your fuel can cause poor power results.
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 06-24-2008, 02:25 PM   #3
No, so long as there are no kinks and the tubbing is not pressed hard against either the pipe or head. Just make sure to check the tubbing often to make sure there is no melting occuring. High quality tubing should be able to handle brushing up against the head and or pipe.
clarksib is offline   Reply With Quote
Old 06-24-2008, 02:26 PM   #4
True but on some makes it is necessary to "loop" the line around the head which might cause a brush or two against it. That situation is fine.
Old 06-24-2008, 03:02 PM   #5
DPowers's Avatar
what about the heat will that make that do something to the fuel to make your engine bog.
Old 06-24-2008, 03:08 PM   #6
mike williams's Avatar
Trader Rating: 45 (100%+)
i can tell you that i know that in full size racecars it make a lot of difference if the fuel is hot or cold, about 10-20 hp and has been dyno tested but not so sure on 3-4 hp nitro motors. just common sense tells me that it would.....i don't run mine anywhere near a heat source, but i have a buddy that wraps around the head for more length and he has had no problems. so i think personal prefference. just my 2 cents
LOSI MF2 ....... too fast for me!!!!!!!!
mike williams is offline   Reply With Quote
Old 06-24-2008, 05:18 PM   #7
jpalessi's Avatar
Yes! The cooler the fuel the better.
Joe Alessi
www.Lucky7RC.com
Old 06-24-2008, 06:12 PM   #8
is there an exception to this?
would it be "smart" to put the fuel in he deep freeze until you are ready to use it? keeping the fuel at like -10c at all times is good for the fuel and performance?
new to rc cars is offline   Reply With Quote
Old 06-24-2008, 06:16 PM   #9
Send a message via MSN to ket2175
Not too sure, but sound interesting can give it a try.
Fatboy love RC
ket2175 is offline   Reply With Quote
Old 06-24-2008, 06:46 PM   #10
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
try to keep the fuel line from directly touching the pipe all you can.. i do run my line around the back of the motor with no problem..
jamminnay is offline   Reply With Quote
Old 06-24-2008, 07:41 PM   #11
bgbelden's Avatar
I wouldn't want my fuel too cold as it can cause condinsation. I wrap my line around the head but i also put shrink wrap and some type of cloth line protector to keep it away from the heat source. Fuel burns, and cause's you to have power, i want that power realized in my motor not my line.
''Life's tough ........
it's even tougher if you're stupid..''
-- John Wayne
bgbelden is offline   Reply With Quote
Old 06-24-2008, 07:47 PM   #12
Djballen's Avatar
You are comparing a gasoline engine to a nirtomethane engine. So what are we supose to do about the fuel tank that is inches away from the pipe? I wouldnt worry about that. Im more worried about my break linkage wearing a hole in my line than anything.
Djballen is offline   Reply With Quote
Old 06-24-2008, 07:54 PM   #13
jamminnay's Avatar
true.. ill take my fuel at room temp!! lol
Old 06-24-2008, 10:53 PM   #14
jpalessi's Avatar
Cool not cold... I just try to keep my line away from heat (pipe,head),my fuel out of the sun, and or even in a Trinity cooler bag. I wouldn't run my line around the head.. I just go around the back of the carb. Going around the head, near the header is prob the hottest area under ur body.
Joe Alessi
www.Lucky7RC.com
MBX5R Fuel Tube Routing - Pics Please superx421 Nitro Off-Road 3 06-28-2008 01:19 PM
Fuel Routing question trout74 Nitro Off-Road 3 03-31-2008 03:00 PM
in line fuel filter question atebit Rookie Zone 2 05-13-2007 09:39 AM
fuel line question???? factory racer Nitro On-Road 5 01-22-2005 03:37 PM
Fuel Line Gundam Singapore R/C Racers 4 01-02-2003 10:28 PM
