Why did my 2 of my OS Vspec carbs break like this in less than a lap?
#16
That's funny! This is the second time this week I've seen the same prob. My friends carb came apart the same way in his Losi 8. IDK!
I do know the thermo coupler is getting stuck in the case due to over tighting the "pinch bolt". I've had that prob before and bought a new one and used some 2 part JB weld to install on the old carb. Just snug up the pinch bolt and use some Lucky 7 Engine Sealent around the base of your carb. Good Luck
#17
does the part which came off fit back in or is it to tight to fit, reason i ask is i actually saw a carb body listed in spares section on a site yesterday while i was looking for bits for mine, so wondered if you were to strip your carb body and hsn assemblies right down so you are left with the 2 blocks maybe if you heated the carb body and froze the other section you may be able to fuse them back together again, just an idea as it seems this is how they are assembled at some point anyway, you may get away with it?? nothing to lose i suppose
#18
mmmm hmmmm well i saw this carby on ebay and its the 2008 version of the v-spec carb and its cheapish, you could try it, it looks different to the one in the pic (the side that came out looks stronger)
http://cgi.ebay.com.au/OS-21-Speed-V...QQcmdZViewItem
cheers
Hope this helps a lil
BTW im only 14 so be easy on me plz
cheers
#19
cheers
cheers
#20
I'm more concerned about finding the cause as that V-Spec runs really good and hasn't much run time on it. I refuse to blow another carb, so it is just sitting and waiting until I feel it is safe to run it again.
BTW, how do I get that thermal sleeve out of the engine? I got stuck in there after removing the last carb.
#21
i had the same thing happen to me today. i think i did it buy tring to adjust the carb position. anyway, can i epoxy it back in place?? if not, what should i use??
#22
TTT
#23
LST
It looks to me like you might have been using a wrench or pliers to twist the carb...the thermal isolator is missing or probably still in the crankcase.
The problem...as you see...is the main and mid needle holder is pressed into the carb body and isn't designed to handle any kind of twisting.
You can reassemble the carb using green loctite intended for retention (609).
Another option...an perhaps GP (OS customer service) might do this for you as a warranty...is to replace the carb body with the new 1 piece carb body that now comes with the OS Speed and maybe the .28 too. (OS p/n 23818135).
