Old 06-23-2008, 04:48 PM   #16
zJatoRad's Avatar
Trader Rating: 31 (97%+)
Send a message via MSN to zJatoRad
Originally Posted by slaytanic View Post
I have tried Go engines and while they seem to have great potential I just can't deal with how finicky the carbs are. I spent a whole race day trying to get rid of a lean bog. It went from too rich to get out of it's own way to len bog in less than an hour on the needles.
you must be one that got a bad HSN, my dad had the same problem, he switched HS needle and the problems went away! in the Go thread there are several other people with the same problem and been solved by changing needles, and I believe as of now the Go Engines will come with a different HS needle.
"Smooth is Slow, and Slow is Fast"
zJatoRad is offline   Reply With Quote
Old 06-23-2008, 07:07 PM   #17
slaytanic's Avatar
Trader Rating: 20 (95%+)
Originally Posted by Chad Phillips View Post
slaytanic - if you choose the Ex-Tech. Ed and I are available at anytime to help with tuning. The TRI40064 race prepped comes pre broken in with needles set and instructions how to re set them if u get lost. TRI40066 is a fully modded version of the 40064. The piston, rod, and crank have been altered for more power. Good Luck with your racing.. If you need anymore info you can contact us here
eb@teamtrinity.com
cphillips@teamtrinity.com
I do not see the TRI40064 anywhere. I thought there was just the stock and the EB version. Is the EB version just broke in and tuned?
Team Epic
Team Terribles~Answer RC~Fastlane Graphics~Torco Race Fuels
XB808 Mamba Max Pro/Tekin 1900kv RC-monster mount and tray 4s
XT8 Hobbywing 150a esc/2000kv combo KILLER! Full rc-monster e conversion. 4s
slaytanic is offline   Reply With Quote
Old 06-23-2008, 07:40 PM   #18
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
The Ex Tech I posted in the link above, is the broken in & tuned one. The fully modified version will be available very soon.
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 06-23-2008, 07:51 PM   #19
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
i am more of a fan of the rb engines.. i have always had good luck with them
jamminnay is offline   Reply With Quote
Old 06-23-2008, 08:10 PM   #20
slaytanic's Avatar
That is misleading then. Amain description says it it modded! I liked the idea of have it broke in and tuned. But it's not worth the extar to me if thats ALL it has on the 64 version. If it is not modded then I would prolly just go with the stock version.
Team Epic
Old 06-23-2008, 08:28 PM   #21
jpalessi's Avatar
Race Prepped Version: http://www.amainhobbies.com/product_...ducts_id/25377
Stock Unprepped version: http://www.amainhobbies.com/product_...ducts_id/25459
The race prepped version is definitely worth the extra cash, as these engines are VERY tight when they come from the factory. Ed disassembles and inspects the whole engine for any defects, then breaks in the engine using Trinity's special break in fuel, then dyno tunes the engine.
Joe Alessi
www.Lucky7RC.com
Old 06-23-2008, 08:36 PM   #22
slaytanic's Avatar
Features:
These are the same engines and tuning that is used by our 1/8th off-road racing team. All engines are modified by Ed Bridges himself to team specs.
All engines will be broken in, carb flow checked and dyno tuned. A dyno spec sheet will come with each motor.
Thanks for clarifying that. All little misleading though don't you think? How much fuel is put through it at break in? Thanks for helping me make a decision!
Team Epic
Old 06-23-2008, 08:39 PM   #23
Trader Rating: 26 (100%+)
Send a message via AIM to cheesecake
RB my opinion but my opinion doesnt count
cheesecake is offline   Reply With Quote
Old 06-23-2008, 08:43 PM   #24
slaytanic's Avatar
Thats right! LOL
Team Epic
Old 06-23-2008, 08:58 PM   #25
jpalessi's Avatar
Features:
Yeah I agree it is a bit misleading. The engines have 500ml of breakin fuel through them. IMHO between the $10 of fuel, and the time it takes, it's well worth having Ed do it. Nothing better then pulling it out of the box, dropping it in, and winning your heat. LOL
Joe Alessi
www.Lucky7RC.com
Old 06-24-2008, 05:49 AM   #26
Maximo's Avatar
So for only $60.00 the Ed Bridges will tear down and inspect each individual engine, then break the motor in and dyno test it ?.... and the dyno sheet given will be the exact dyno from each individual engine, not just a pre done dyno from a test motor ? I will say i am skeptical as thats a hell of alot of work to be offering for only $60.00.. I know first hand that all that work, combined with the wear and tear on the dyno is worth much more then the $60.00 being charged...... You wouldn't catch me dead doing that much work for that little $$$$$$..either way if that is what is truly being offered then its the deal of the century and well worth every penny......... Honesty that sounds too good to be true, but if thats what your truly offering props to you ! 500 ml fuel is at least 1 hours worth of running on a load bench, tear down,inspection, micing and rebuilding also takes time, then to individually dyno test each motor is unreal, especially for $60.00 !!! WOW !
Maximo is offline   Reply With Quote
Old 06-24-2008, 06:27 AM   #27
Thats right! LOL
Its ok keep talking and they wont let you out of canada
Old 06-24-2008, 08:15 AM   #28
jpalessi's Avatar
Originally Posted by Maximo View Post
So for only $60.00 the Ed Bridges will tear down and inspect each individual engine, then break the motor in and dyno test it ?.... and the dyno sheet given will be the exact dino from each individual engine, not just a pre done dino from a test motor ? I will say i am skeptical as that's a hell of a lot of work to be offering for only $60.00.. I know first hand that all that work, combined with the wear and tear on the dino is worth much more then the $60.00 being charged...... You wouldn't catch me dead doing that much work for that little $$$$$$..either way if that is what is truly being offered then its the deal of the century and well worth every penny......... Honesty that sounds too good to be true, but if that's what your truly offering props to you ! 500 ml fuel is at least 1 hours worth of running on a load bench, tear down,inspection, missing and rebuilding also takes time, then to individually dino test each motor is unreal, especially for $60.00 !!! WOW !
YES Maximo that is the procedure! That is why im telling this cat to buy the EB Version. I KNOW these are facts as I'm at the shop hangin with Ed frequently, and he is always BUSY. Most of the time there is one mill on the bench and one on the Dyno. lol!
Joe Alessi
www.Lucky7RC.com
Old 06-24-2008, 11:44 AM   #29
Maximo's Avatar
I dont know how you guys can offer that for $60.00, but regardless thats a very worthwhile investment....For $360.00 ready to go all broken in this Extech does seem like a dam nice motor.
Old 06-24-2008, 12:11 PM   #30
ngo8's Avatar
Send a message via ICQ to ngo8
i would go for the extech just remember ed bridges the best motor man in the buisness you cant go wrong with that ,and rb tend to flame out alot as i have seen peoples motors do at my track and they are not rookies and dont forget yannick aigoin lost the worlds 2 years ago cause his rb flamed out with 10 minutes to go in the main ,they love to flame out .
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Trinity EXTECH .21 Fierle03 Offroad Nitro Engine Forum 2130 06-09-2011 07:01 AM
FS Trinity .21 extech franklucas R/C Items: For Sale/Trade 2 08-03-2008 08:24 AM
EB Tuned Trinity ExTech .21 xsandmanx R/C Items: For Sale/Trade 5 07-02-2008 06:48 PM
E.B. MODS TUNED EXTECH .21 icemandolmite R/C Items: For Sale/Trade 1 05-26-2008 04:05 PM
need help can't decide what to buy next classic xl Monster Trucks 6 08-13-2005 12:46 PM
