Old 06-23-2008, 12:48 AM   #1
BSC
BSC's Avatar
Trader Rating: 48 (100%+)
Default Rebuilding Hot Mods RB C6 with standard kit
Does anyone know what will happen if i rebuild my HOT MODS C6 BB T7 with a standard sleeve , piston and rod ?
What will happen if i use the old HOT MODS sleeve with the new piston and rod ?
I rebuilt my HOT MODS WS7 with a standard rebuild kit and it took me for ever to tune it I had to take the LSN out 2 turns from standard to 7 turns out to get to run then lean the top right in to get it to perform I didn't think the crank case was milled anywhere behind the sleeve . Someone told me the crank is milled , would this be the difference .
It is very touchy to temp changes now and takes a lot more tuning than before
Anyone got any ideas or experience with this
Kyosho
Team Associated
Hobbywing /SMC/LFR/AKA
www.coast2coastrc.com.au
Logan Offroad - The Brickyard
BSC is offline   Reply With Quote
Old 06-23-2008, 07:25 AM   #2
wes95_z28's Avatar
DO NOT, AND I MEAN DO NOT USE YOUR OLD SLEEVE WITH A NEW PISTON!!!!!! These things have to be broken in together, and as far as the rest of your question goes. If you put a stock sleeve and piston in your C-6 your back to a stock C-6 again. I have never owned a modded motor but I am pretty sure that they do no work to the block. Even if they do there is no way it could adversly affect the new sleeve or piston you are putting in. All you are doing by replacing it, is getting rid of the modded (ported) sleeve.
Wes
Kyosho 777 WC w/ big bores, RB S5, ACE 1313 s., Air 357 t., JP-3
HPI Savage X SS, Axial .28, Hitec 5645 Steering servo
Nitro TC3, O.S. .18 CV-R
Associated RC18T, Brushless, Lipo
wes95_z28 is offline   Reply With Quote
brushed mods vs brushless mods b-man777 Electric Off-Road 12 03-21-2008 04:42 PM
Rebuilding vs Pinching vs New CRASH Nitro Off-Road 1 09-09-2007 08:24 AM
Mods and regional Mods names turn to Green? Mr. Shookie R/C Tech Site Forum 2 07-08-2007 08:50 AM
Rebuilding my CV-RX Vismund Cygnus Electric Off-Road 0 02-25-2007 05:51 PM
Rebuilding O.S 12 CVR yodace Electric Off-Road 2 09-11-2006 05:05 PM
