Old 06-22-2008, 10:16 PM   #1
Default Protecting your chassis
Hey all
How do you guys protect the under side of your chassis? Its not that important but i am about to try a new BCE chassis and want to keep it in good condition if possible. I have skid plates front and rear but is there any sticker coating etc that I can use that works for the whole underside?
cheers
MBX5R - OS VSpec - Futaba 3PKs - Hitec 5955's- LRP Lipo - Proline
MBX5T - RB C6 L2G - Futaba 3PKs - Hitec 7955's - LRP Lipo - Proline
pracy is offline   Reply With Quote
Old 06-22-2008, 10:25 PM   #2
asw7576's Avatar
No need..... it meant to be scratch.
No sticker will survive underneath the chassis.
Old 06-23-2008, 06:11 AM   #3
TeeKuang's Avatar
I'm using clear epoxy adhesive such as Araldite, mix them properly and spread it on the chassis about 2-3mm thick, once the epoxy wear out, you can redo it anytime, by peeling off the old one with knife.
Tee Kuang.
Best Regards, Tee Kuang
Rovan 290S
Killer Bee Kill switch | Outerwears | hydraulic brake | Ace DS-1015 |ADA Rear billet hub bearing carrier | Hostile Nightmare MX | RCMOD Closed clutch |
Gasoline POWER : Malaysia Large scale hobby
TeeKuang is offline   Reply With Quote
Old 06-23-2008, 06:25 AM   #4
rice_man's Avatar
Trader Rating: 112 (100%+)
Associated Chassis Protective Sheet. Peel and stick. The only issues is cutting out holes once it's stuck down to access the screws. Not a big deal though if you want the protection. Once the sheet is down I put a skid plate for good measure. You might need a bit longer screws for the skid plate with the added thickness of the protective sheet.
rice_man is offline   Reply With Quote
Old 06-23-2008, 06:36 AM   #5
Trader Rating: 19 (100%+)
J-concepts also makes chassis tape. I find the J-C one more durable, its cheaper and you get 2 pieces over AE's 1 piece. For truggy you will need 2 pieces anyway because the stuff is made for 10th scale. Use an E-xacto knife for the screw holes.
malik is offline   Reply With Quote
Old 06-23-2008, 10:14 PM   #6
thanks guys. i have a couple j concepts protectors on their way.
cheers
Old 06-23-2008, 10:39 PM   #7
Nik
Nik's Avatar
those sheets are meant for carbon fiber chassis'. you dont really need it for aluminum chassis...
I can ride my bike with no handlebars.
Nik is offline   Reply With Quote
Protecting the paint Telnets Painting, Designs, Graphics and Photography 8 08-01-2008 07:28 AM
Protecting your lower chassis? TGA78 Nitro Off-Road 6 07-04-2007 10:40 PM
Protecting the bottom of the chassis Wing Chun Australian Racing 8 03-26-2007 03:35 AM
protecting decals seasterling Painting, Designs, Graphics and Photography 5 04-04-2005 10:52 AM
Protecting Bottom Of Chassis Calvin Ng Electric On-Road 11 06-24-2003 08:36 PM
