Old 06-23-2008, 06:32 PM   #31
jgtruggy's Avatar
Originally Posted by looneytune View Post
By far the easiest way.^
+2 for the naptha and dunker.
I like to leave the parts in the dunker and take the air compressor to it. Comes out dry and perty I put my diff case in as well. I like things perfect for the next race
Losi SCTE
Tekin RX8/Tekin Pro-4 4000kv
Topgearhobbies.com
jgtruggy is offline   Reply With Quote
Old 06-23-2008, 07:19 PM   #32
Integra's Avatar
Not cleaning out the gears and cup properly is just being lazy imo....what u guys dont wnna get ur hands dirty...
ps what if a peice of bevel gear is somehow lodged in the corner u neglected to clean out and it makes its way into the gears...then u have a set of blown bevels.....Fun Fun.
Old 06-23-2008, 07:24 PM   #33
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
well if there was a piece of bevil in the case werent they blown already?? lol
jamminnay is offline   Reply With Quote
Old 06-23-2008, 07:35 PM   #34
Integra's Avatar
No not really....ive found peice's of the teeth before the entire gear let go.
Old 06-23-2008, 10:12 PM   #35
Is there anything wrong with just using unleaded petrol?
I pull them apart, remove the o-ring and gasket and put everything else in petrol for about 5-10mins and then wipe them dry. I wipe the o-rings with a paper towel and put it back together...
These are for mbx5r diffs. mind you the spur gear does show some signs of rust or something weird on the outside but everything else is fine.....
MBX5R - OS VSpec - Futaba 3PKs - Hitec 5955's- LRP Lipo - Proline
MBX5T - RB C6 L2G - Futaba 3PKs - Hitec 7955's - LRP Lipo - Proline
pracy is offline   Reply With Quote
Old 06-24-2008, 01:48 AM   #36
slow coach's Avatar
open diffs take out gear sit on absorbent kitchen paper then use cotton buds to clean out case, wipe over gears and shims with rag or paper, re-grease re-oil re-assemble done, if theres a cleaner way it would be nice
Kyosho MP9TKI2 soon to be TKI3, Novarossi, SMD, GM Racing, www.grccc.org
a great wife and lovely kids
what more can you ask for
a win on the lottery :D
slow coach is offline   Reply With Quote
Old 06-24-2008, 03:13 PM   #37
Akhor's Avatar
1) Take diffs apart - remove o-rings.
2) Put in paint thinner
3) Swish around for 10 seconds
4) Remove from pain thinner.
Everything comes out sparkling and very easy and quick.
Akhor is offline   Reply With Quote
Old 06-24-2008, 03:27 PM   #38
Trader Rating: 47 (100%+)
Yo B!
I found paint thinner was really rank versus varsol. Varsol worked great...I'm going to buy some Naptha and try it next. Canadian Tire maybe? It's just camping fuel isn't it?
Horizon Hobby/Losi
Sanwa
Savox
HobbyWing
Hyperion
SUNA is offline   Reply With Quote
Old 06-24-2008, 08:58 PM   #39
Akhor's Avatar
Originally Posted by SUNA View Post
Yo B!
It's true the paint thinner does stink like hell, but it works.
Maybe I'll try the varsol next!
Old 06-25-2008, 12:17 AM   #40
you mean BESIDES the price of gas these days?
Kyosho / Team Orion / AKA / JTP / Sharkbait Designworks / RC Tracks of Las Vegas
Chris Jarosz is offline   Reply With Quote
Old 06-25-2008, 03:35 AM   #41
Trader Rating: 19 (100%+)
Naptha stinks bad too, but it cuts silicone diff oil real well.
Dirt's for racing,asphalt's for getting there!
pooldoc is offline   Reply With Quote
Old 07-02-2008, 03:44 PM   #42
rallyebmx's Avatar
Trader Rating: 21 (100%+)
What aisle is Naptha in at Lowes? I couldnt find it and they didnt know what I was talking about
rallyebmx is offline   Reply With Quote
Old 07-02-2008, 04:11 PM   #43
Default Diff oil change.
Man you guys go all out. I just drain, disasemble, wipe clean, drop in alcohol bowl, leave do something else for a few minutes; drain and put back together with new diff fluid. I really do not spend a lot of time on this. Losi uses mostly dog bones, so I do but dry lub on those locations, and if needed I have a lot of spare bearings, and replace them every so often. But man I am running out of space for all the stuff for this game. I need to build a bigger shop. I stick to the KISS method. Oh! and I buy a lot of spare parts.
Relay8039 is offline   Reply With Quote
Old 07-03-2008, 08:19 AM   #44
Madbrad's Avatar
Trader Rating: 29 (100%+)
How offten should the diffs be cleaned? I've seen some people post they do it after every race, isnt that a little over doing it? What happens when you dont clean the diffs? Is there any signs that point to the diffs need to be cleaned?
Madbrad is offline   Reply With Quote
Old 07-03-2008, 09:03 AM   #45
Default Diff cleaning
Before each big race I redo everything. Bearings, diffs, I check every screw. I put calipers on every link arm and record everything in the log book. But if I am just doing routine club races, I do change my fluids unless I feel the diffs not doing what they are supposed to. The oil is not like transmission fluid, and does break down over time. But really unless it a big race I just plan on changing the diff stuff once a month. check the bearings when I have them exposed. I do change my clutch bearing religously. Anything on the clutch that is not perfect is replaced. I also change the clutch springs before every weekend. But I have two identical clutch setups, so I really just change the them out when I have some free time. On big race days, I will have both clutch setups slightly different, so If there is a needed change the swap out only takes a few minutes.
How do you guys clean your gear diffs? wstuart Nitro Off-Road 7 07-05-2008 12:15 AM
ok guys i havnt been in RC for afew months and finally have decided to clean out my g HQ-MOTORSPORT Australia For Sale/Trade 27 02-27-2008 02:51 AM
How do you guys clean up your buggies after bashing? civiclized esi Singapore R/C Racers 4 02-03-2008 06:47 AM
How to clean a one-way diff.? sbs Electric On-Road 7 03-12-2007 07:24 AM
[B]Fioroni Center Diff And Front Diff And Ofna Torsion Diff For Hyper 7[/B] Imdadundada7 R/C Items: For Sale/Trade 22 08-07-2006 10:11 PM
