Old 06-22-2008, 12:17 AM   #1
Default Differences between o.s speed .21 v-spec speed alum and magnesium.
Is there any difference between these engines other than the heads?
Im looking to buy one, and i have found one for a good price.
There is a 20-30 dollar difference between the engine and since the difference is so small i wonder what engine will hande heat best. The aluminum head or the Mag head.
Alu head
Magnesium
Hans_Andersson is offline   Reply With Quote
Old 06-22-2008, 12:39 AM   #2
Searched more and found this.
O.S. Speed .21VZ-B V-Spec ......Alloy Head or Magnesium??
Sorry for any anoyance.
Old 06-22-2008, 02:43 AM   #3
Registered User
Yes thats correct, the thermal conductivity of aluminium is greater than magnezium... therefore better heat transfer and better cooling.
Loop&Roll is offline   Reply With Quote
Old 06-22-2008, 06:26 AM   #4
Scottmisfits's Avatar
I didn't read that but Magnesium is harer to work with and is more expensive. It doesn't handle the heat quite as well but it's lighter. That was the advantage of it.
The Aluminum ead Speed is the same motor with an aluminum head to help dissipate the heat better. When it's a little cooler out I'll use my Mag head. I was using the Mag head motor in Arizona for awhile though, and I had no issues.
Scottmisfits is offline   Reply With Quote
Old 06-22-2008, 07:51 AM   #5
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Weight is the biggest difference between the two. The magnesium version will take some weight off the top of the car. Other than that, I have seen no heat related differences or issues between the two versions. I have been around quite of few of these engines so far, personally owning two Mag versions myself, and tuning a couple AL versions at the same time.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 06-22-2008, 08:20 PM   #6
bgbelden's Avatar
Can anyone tell me which engine is better overall and why ? Reg V-Spec or speed version?
''Life's tough ........
it's even tougher if you're stupid..''
-- John Wayne
bgbelden is offline   Reply With Quote
Old 06-22-2008, 09:49 PM   #7
ezveedub's Avatar
IMO, overall the Speed is better in the long run. Smoother power deliver and faster bottom end spool up for jumps. The DLC coated crank has almost no wear in most cases when time for a rebuild, as the stock V-Spec crank pin will most likely be oval.
Old 06-23-2008, 03:43 AM   #8
bgbelden's Avatar
Thanks, now if i just knew what a crank pin was....
-- John Wayne
Old 06-23-2008, 03:49 AM   #9
maximugen's Avatar
Send a message via MSN to maximugen
crank pin is the small pin found on the end of a crankshaft that the conrod pivots on. most crankshafts show some wear here, but because of the DLC (hardcoating) process of the OS speed, there is pretty much no wear at all
Mugen MBX5r - N/R 367 / Sirio bx STi
Mugen MST1 - JP RS12
Losi JRXSR- LRP SPX and Speed Passion 17.5R
HPI Savage - N/R 528
Trex 250
maximugen is offline   Reply With Quote
Old 06-23-2008, 10:02 AM   #10
bgbelden's Avatar
Thanks. Now i have a speed crank and reg OS conrod, can i put them in my OS and made it a "speed"?
-- John Wayne
Old 06-23-2008, 03:33 PM   #11
ezveedub's Avatar
I believe you'll need the p/s set also. Just the crank may not yield the same performance. I believe the piston is differnent from the stock V-spec version. Also add the ceramic bearing.
Old 06-23-2008, 05:02 PM   #12
imaxx21's Avatar
Send a message via AIM to imaxx21
if you use a speed crank, you have to use a speed rod...
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
O.S. Speed 21VZ-B V-spec Aluminum or Magnesium josh_c Nitro Off-Road 4 06-23-2008 12:35 AM
OS Speed Magnesium Head V-Spec FOR SALE: mdrnizd R/C Items: For Sale/Trade 5 05-29-2008 06:42 PM
OS SPEED MAGNESIUM COOLING HEAD NEW O.S. V-SPEC VZB RC8 GTempleton R/C Items: For Sale/Trade 1 03-10-2008 11:57 PM
O.S. Speed .21VZ-B V-Spec ......Alloy Head or Magnesium?? Crocket Nitro Off-Road 17 02-13-2008 05:05 AM
