Old 06-25-2008, 09:35 AM   #16
just checking too see if you got it fixed
www.nitrojunction.com
The #1 site for all your nitro needs
egobuster1 is offline   Reply With Quote
Old 06-27-2008, 06:49 PM   #17
ok i got my bearing in today.(mail) i'm bout to go tackle replacing it. it's the one behind flywheel. anything i need to be aware of or any tips on makin the job easier so i don't tear anything up. thanks
stalk is offline   Reply With Quote
Old 06-27-2008, 08:08 PM   #18
well while waiting on a reply i done some research. do i have to heat it up to get this bearing out? also do i have to take the sleeve out? thanks
Old 06-27-2008, 08:17 PM   #19
you need to take the everything out of the engine..piston,sleeve,crank,carb, everything
most ppl heat them to bout 350 for like 5-10mins idk everyone does it different just watch it to make sure you dont cook it and then once its heat up pull it out and try and get the bearing out
Old 06-27-2008, 08:21 PM   #20
will the sleeve come out easy or will it have to be heated to get it out?
Old 06-28-2008, 11:33 AM   #21
u never heat to get the piston sleeve out..ull damage it
it will probably slide out on it own if not but a zip tie through the exhaust port and bring it up through the top of the motor then crank the motor over and the piston will push on the zip tie and will push the sleeve up
Old 06-29-2008, 02:45 PM   #22
got it all done and it runs great. thanks for all the help
